Guest a.jennett Posted November 4, 2014 Share Posted November 4, 2014 (edited) thanks! Edited November 4, 2014 by a.jennett (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest a.jennett Posted November 4, 2014 Share Posted November 4, 2014 hi there i just got a supra and the brakes need replacing and i have been looking into up grading to the turbo rotors and calipers. is it as easy as bolting them off and on or do i need to change the lines and get spacers ect? i have 17inch rims on the back and have heard that they can already clear them THANKS Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 4, 2014 Share Posted November 4, 2014 (edited) Pretty much unbolt the old & fit the new but you'll need to modify the back plates or remove them. Check you wheels will fit over them as they're a lot bigger than the 2 pot and 1 pot calipers, you'll need a 17" diameter wheel minimum and you'll also need to check the clearance between the face of the caliper and the back of the spokes. Do a full fluid change and replace the brake lines. If your fitting old second hand calipers check the outer dirt seals as these perish with age. Also make sure you fit the rotors/discs on the right way round as they're handed, left and right. If they're OE discs L & R should be cast into them. Edited November 4, 2014 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
safcdixon Posted November 4, 2014 Share Posted November 4, 2014 Its really simple tbh dude, unbolt the 2pot calipers and discs and bolt the 4pot calipers and discs in, the lines etc are all the same, you may have to bend the heat shield slightly if you dont have the 4pot sheilds though, regarding your wheels, what are they? Stock 17"? If so they will fit for sure, if not alot depends on spoke design and offset Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 4, 2014 Share Posted November 4, 2014 Two threads on same topic ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 4, 2014 Share Posted November 4, 2014 LH and RH side? F & R? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 4, 2014 Share Posted November 4, 2014 Are all the other parts of the brake systems the same? Master cylinders, lines, ABS etc? Quote Link to comment Share on other sites More sharing options...
Guest a.jennett Posted November 4, 2014 Share Posted November 4, 2014 there 17 inch non stock and iv heard you can just bend the heat shield a bit to fit them and everything else is the same and it dosnt have abs or it dosnt work ha the big black lines down my road when i tested it would agree. whooops thanks for the help guys!!!!!!! Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted November 4, 2014 Share Posted November 4, 2014 I did a pictorial how to about ten years ago. I will have to re-do it when I finally get around to fitting the brand new UK spec brakes I bought for the same price knackered old ones sell on here for I found that the dust shield did not bend so well so I tin snipped it in about inch segments and bent it out of the way that way. The wheel issue is bound to be the biggest stopper as those callipers are big assed bar stewards and need some sensible offset to clear them Quote Link to comment Share on other sites More sharing options...
