Experience with Coil Pack Connectors on ebay
Clausz
Hi All
Do any of you have experience with these? http://www.ebay.co.uk/itm/6-x-Toyota-1UZ-1JZ-2JZ-1JZGTE-2JZGTE-Supra-Soarer-Coil-Pack-Connector-Loom-Plug-/111436424675?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19f220e5e3
I will just make sure that the quality is good, before I buy a couple of sets.
Best Regards Claus
Unless you already have the correct crimping tool available, I would recommend that you go with ones already machine crimped with tails on.
You can solder your wires onto the pins, but then unless you are super careful you may have a problem getting the actual connectors to slip back into the casing correctly, the extra thickness added by soldering makes the connectors a tight fit into the housing.
