play in auxiliary idler pulley
simbasupra
I am sure it's fine, unless the bearings are from somewhere turning out total junk, they are what they are. (Caveat, you can get special clearance bearings in some popular sizes, called a "C" number. "Normal" or C3 being the common ones. But don't even consider buying very expensive tight clearance bearings for here, it's a none critical application for a bearing.
http://www.skf.com/group/products/bearings-units-housings/ball-bearings/deep-groove-ball-bearings/single-row-deep-groove-ball-bearings/internal-clearance/index.html
