Toyota Supra Twin Turbo (hybrid) BPU Auto
supra_ufo
Engine Type - TT
Engine Spec - JSpec, Stock Injectors, Walbro 255 pump, HKS FCD, Stock SMIC
Turbo - CR Rebuilt JSpec Turbo (to stock specification)
Fuel Used - Shell V-Power
Exhaust - 3" custom exhaust with double decats and 1.1 bar restrictor
Transmission - Stock Twin Turbo Auto
ECU - Stock
Mapped By - N/A
Dyno Used - Evotune Dyno Dynamics
Power figure - 369 HP Fly
Torque figure - 330 ftlb
Boost Pressure - 1.1 Bar
DYNO_L9_UFO.pdf
Edited by supra_ufo (see edit history)
  • 1 year later...
Update
Went on aother dyno session a few weeks ago, major change is the addition of the boost controller which makes a massive difference to performance. Other changes are in bold.
Engine Type - TT
Engine Spec - JSpec, Stock Injectors, Walbro 255 pump, HKS FCD, Front Mount Intercooler with 3" pipe work cold side and 2.5" hot side
Exhaust - NUR SPEC R with double decats and 1.1 bar restrictor
ECU - Stock, Greddy OLED Booost Controller (running 1.28BAR for this session)
Mapped By - N/A
RS TUNING IN LEEDS - DYNO DYNAMICS
Power figure - 399.7 HP Fly
Torque figure - 430 ft lb
Boost Pressure - 1.28 Bar
Need to do another run at 1.4BAR, I want to probably setup my boost controller so will book a session in at a Dyno
Graph attached
Supra DYNO 2016.pdf
Big difference in the torque.
Much more like it :D
yep feels good, didnt think it would be that much of a difference but it is! Its also ironed out a few flat spots I had before or hesitation, I think because its bypassed some VSV which may have been slightly faulty
  • 3 weeks later...
  • 3 weeks later...
You have to be in Manu mode with O/D off. Start with the revs as low as you can, avoiding kickdown
Hmm....Does that mean I have to put my traction control fuse back in? I pulled it out as soon as I bought the car lol.
Also I have a hi stall torque convertor installed. Will that make it trickey?
I read something once about earthing out a pin on the ECU to get it to hold in 3rd gear?
  • 2 months later...
  • 2 weeks later...
