Jellybean Posted October 29, 2014 Share Posted October 29, 2014 Had to get a new regulator for the window , Is there a trick to adjust them. I adjusted the bump stops as the window was catching the frame when you closed it I still get slight wind noise , it is not sealing fully, the rubber on the frame encapsulates the window when closed, there's less than a mm in it , with the window hitting the frame so I dont think I can adjust the bump stop again Any idea's , in comparison to the passenger side it looks spot on Toyota also alter the design of the new regulator so maybe that is a factor Was told Sometimes if they are too tight it will cause wind noise Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 16, 2014 Author Share Posted November 16, 2014 anybody , fedup taking the doorcard on and off , adjusting it Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 18, 2014 Author Share Posted November 18, 2014 Maybe it is got to do we the new design of the regulator , seems to be a common problem with the Supra when guys swap out the regulator for a new one The window is bolted on via 3-4 bolts , the curvature of the glass is defined by the angle of degree of the regulator Unless a window installer guy has some mystical magical tool or technique , I am not too sure, at this stage the passenger and drivers windows sit and look the same to the naked eye Passenger window has no wind noise as it was installed at factory Worth taking to a professional window installer? Quote Link to comment Share on other sites More sharing options...
BOB B Posted November 20, 2014 Share Posted November 20, 2014 I have also just changed my drivers side for a second hand one, ( the wire snapped on the origonal one) and I have the same problem, hoping to get out on a dry day and have a look, yeh it is a pain in the bum getting to the mech, I'm going to try and adjust the bottom of the guide rail where it's fixed to the door frame, I'm thinking if I move that end away it should move the top of the glass in, to get a better seal. It's just when you get above 60 that the high pitched whistle becomes propper irritating. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 20, 2014 Author Share Posted November 20, 2014 Exact same problem as me ! Let me know , how you get on , adjusting the bump stops is not the answer Quote Link to comment Share on other sites More sharing options...
TEFLON Posted November 24, 2014 Share Posted November 24, 2014 Subscribed. Could it be the seal instead? Quote Link to comment Share on other sites More sharing options...
Ric Posted November 24, 2014 Share Posted November 24, 2014 you can adjust the "lean" of the window by the adjustment screw at the bottom, centre of the door, under the handle. one way will push it away from the seal, the other push it against the seal. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 24, 2014 Author Share Posted November 24, 2014 you can adjust the "lean" of the window by the adjustment screw at the bottom, centre of the door, under the handle. one way will push it away from the seal, the other push it against the seal. Will have to look at that , the noise for me is right beside my ear , the corner of the glass meets the rubber ; I think it just needs to press in more against the rubber to seal properly Quote Link to comment Share on other sites More sharing options...
Ric Posted November 24, 2014 Share Posted November 24, 2014 thats the adjustment you need then. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted November 24, 2014 Share Posted November 24, 2014 you can adjust the "lean" of the window by the adjustment screw at the bottom, centre of the door, under the handle. one way will push it away from the seal, the other push it against the seal. I never knew this, although my window whistles it comes from the area by the wing mirror. I guess that's probably down to the rubber seals though. Quote Link to comment Share on other sites More sharing options...
BOB B Posted December 2, 2014 Share Posted December 2, 2014 Hi there, right I managed to get some time to have a look at this the other day, I took the door card off but I only had to move a bit of the plastic aside to get to a few things. I loosened off the regulator bottom holding bolt a little, then I loosened off the top bolts a bit to make sure they were as far down (in the holes) towards the floor as they would go, then niped back up. I then loosened the adjusting nut at the bottom right of the regulator a full turn. I then closed the door to check it would close without catching, and it did appear that the glass was a slightly better fit at the top, so took it for a drive on M27, bingo no whistling and no drought. I think it just takes a lot of fiddling and checking before you put the door card back on, and I think I was probably a bit lucky. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 6, 2014 Author Share Posted December 6, 2014 (edited) What does the nut adjust ? loosened the adjusting nut at the bottom right of the regulator a full turn. I have the glass sitting as low as possible in the regulator , and I was adjusting the bump stops at the top of the door Didn't notice an adjusting but at the bottom Thanks for the heads up ! hopefully will sort out mine Edited December 6, 2014 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted December 6, 2014 Share Posted December 6, 2014 Been having the same problem on/off for a year or so now Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 6, 2014 Author Share Posted December 6, 2014 Been having the same problem on/off for a year or so now In the last couple of weeks I have the door card off about 6 times now lol I have it down to less than 3 mins to get it off Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 7, 2014 Author Share Posted December 7, 2014 Got mine done Repo steps Make sure the window seats as far back against the wall of the door card (Pic one) ,Undo the 3 bolts on the regulator and push the window towards the rear of the car, loosely hand tighten bolts (Pic 2) Fully close the window, measure it is seated close to the rear quarter window compared to the opposite window , just use you finger to get a rough measurement (mine was sitting too far forward in the regulator ) With the window fully closed , close the door, the top of the window should be encapsulated by the rubber around the door If you window is seating too high it will crush the rubber , resulting in wind noise You need to adjust the bump stops , front and rear; to lower or higher your window. As a reference I used the opposite window , fully closed , with my finger I tried to guage how far the window was up into the rubber , gives you a good reference point to test the window is seating correctly Adjust the bump stops if you need to , mine was up too high crushing the rubber , some small adjustments and visual/finger comparisons to the opposite window , the rubber looks to be encapsulating the window as it should **my biggest error was not having the window seated correctly in the first place against the wall of the door card Pic 1 Pic 2 Pic 3 -- Bump stop Adj Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 22, 2014 Author Share Posted December 22, 2014 I am going to throw my car in the Bin lol Might be useful to somebody Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted February 14, 2016 Share Posted February 14, 2016 (edited) While reverting back to stock speaker pods I came across this lovely bodge up.. Drivers side Passenger side Can anyone supply me with the part numbers for what I need or even better an exploded diagram so I can see what should be there? Thanks Edited February 14, 2016 by ballsdeep (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted December 14, 2018 Share Posted December 14, 2018 Did you people manage to come right with this? Fitted my new door panels and have had my window close very loudly always when I closed the door. I even adjusted the door like an idiot thinking it was that. Yeah I need new rubbers but the window had too much wobble/play in it. I did loosen 2 bolts holding the window to the rubber and moved it up and tightened it. That helped. Guess last thing for me to try to fix it entirely is do that adjustment at the bottom. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 14, 2018 Author Share Posted December 14, 2018 Yep, just needed to adjust the tilt angle of the window to create the seal, in Repro steps above Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted January 8, 2019 Share Posted January 8, 2019 I remember doing this 2 years ago on mine, window regulator cable snapped. What a pain in the a** this is! I got it as close as possible before giving up...it would shut fine but leave the noise creating gap, or just touch the bottom of the rubber at the top. This is how I've left it, just have to push the glass in very slightly when closing the door. Ill have a look again this summer, sounds like the tilt needs adjusting as i know the height is as close as ill get it! Someone Sticky this thread! Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 9, 2019 Author Share Posted January 9, 2019 It is very easy to adjust the angle , just follow the workshop manual above Before I found out how, Toyota and/or no glass fitters would get involved Quote Link to comment Share on other sites More sharing options...
squiffy Posted January 9, 2019 Share Posted January 9, 2019 I need to have a proper go at this! I changed my regulator and I've had the door card on and off multiple times since trying to get it right lol Quote Link to comment Share on other sites More sharing options...
Dave Posted January 18, 2019 Share Posted January 18, 2019 just done my drivers side window opens and shuts good sits in the rubbers ok but when i shut the door its not the nice thud it used to be or like the passenger door.maybe mines to tight on the rubbers,need to adjust the tilt think this is the bottom adjuster.cant be arsed now as the weather is crap. Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted January 7, 2023 Share Posted January 7, 2023 I just arrived at this thread after replacing my window regulators and both the window edges now catch the top trim. Naturally I discover this after all the weather seal has been sealed back in and everything reassembled.. This is the tilt adjuster pictured to angle the window inwards from below. I have about 14mm of exposed thread on the rear most adjuster, and 8mm exposed thread on the front to give an idea of what works without catching the top. Quote Link to comment Share on other sites More sharing options...
The Raven Posted January 9, 2023 Share Posted January 9, 2023 The height ones are at the top of the window, Mine as you can see was to low and alllowing water in, If its catching maybe move them down a bit? Mine 1 Quote Link to comment Share on other sites More sharing options...
