Swampy442 Posted October 29, 2014 Share Posted October 29, 2014 Does anyone know the answer to this? Still trying to get to the bottom of the gearbox snags on the Crown. Using Techstream I was able to measure the trans temps, sat at idle for a while and the temp was reading close to 95 degrees, I think thats too hot. Any opinions? By the way this car has a weird set up for cooling the fluid, normally its in the bottom of the rad, on this car its a heat exchanger on the side of the engine. I might have to runs cooler and see if that helps. Quote Link to comment Share on other sites More sharing options...
David P Posted October 29, 2014 Share Posted October 29, 2014 Transmission temp should range from 75°C @ cruise to 100°C @ WOT. http://www.mkivsupra.net/vbb/group.php?discussionid=82&do=discuss Quote Link to comment Share on other sites More sharing options...
