shetlandsupra Posted October 24, 2014 Share Posted October 24, 2014 Just put hks t51r turbo kit on plus whifbitz fuel rail and 1000cc Asnu injectors, hks cam gears, oil pump etc what should I set my fuel pressure to just to start it before I take it to be mapped Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted October 24, 2014 Share Posted October 24, 2014 3 bar is about normal mate Quote Link to comment Share on other sites More sharing options...
shetlandsupra Posted October 24, 2014 Author Share Posted October 24, 2014 I thought that yeah thanks Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 24, 2014 Share Posted October 24, 2014 Unless the injector manufacturer specified another pressure. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 24, 2014 Share Posted October 24, 2014 3 bar base pressure is common. I'm running 4 bar base pressure, as the injectors were too high in DC at 3 bar. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 25, 2014 Share Posted October 25, 2014 Unless they are new technology injectors and are capable of running very low DCs/durations at lower fuel pressures, big injectors often need higher base pressures to be able to run a reasonable spry pattern at idle. Quote Link to comment Share on other sites More sharing options...
