The Mega Aerotop Leak Fix Thread FAQ
Ric
The pop up things create so much wind noise it's Unbearable.
However you need to install the bracket what holds the fins to the body as this holds the fwd seal to the bodywork.
I kept this bracket but removed the fins from it by drilling out the rivets
Without the bracket the fwd seal will be loose and the water won't make it to the drains
  • 6 years later...
  • 5 months later...
Hi guys, I know this is an old post but I can't find anything newer, can someone tell me where the drain hoses are meant to run to?  Someone pulled them out of my car before I brought it and I can't find any information for where they run after the pillars, mainly the passenger rear drain hose is the most important as I can't even see where it could exit to let water out at all.
Any help would be great 👍
