Replacing bottom sump
Dave
So I have to replace the bottom sump managed to get one off of josh .
It's got the remains of sealant gasket on it can I get away with puting more gasket seal on top or would I need to remove the old seal first ,and could anyone recommend a good gasket sealant
Anyone done this will the sump come off without lifting the engine?
I use the Loctite stuff or equivalent. But my reason for sticking my oar in here is to say *DO NOT* use too much new sealant. it'll ooze out inside the pan and can come away and start to choke the oil pump pick up filter gauze. I see this all the time on engines rebuilt by people. I sometimes see totally scrapped engines due to this, after an over enthusiastic use of the stuff. In fact one forum member posted photos of the underside of his newly bought single turbo (huge HP thing from Ireland). Had I seen the photos I'd have suggested not to buy it, sealant oozing out everywhere. The engine died of oil starvation shortly after he bought it. Oil pick up gauze blocked with sealant.... Engine scrap. Steel crank, rods, pistons, turbo, head, all scrap.
