James Posted October 16, 2014 Share Posted October 16, 2014 I know these threads have been done before (I conducted a search of course and have done some reading ) but I was just curious as to whether there are any new opinions on clutch options? I'm running a T88-34D single at (an estimated, yet to be dyno'd) 650bhp. As the car is VVTi it has a V161. I have, as mentioned, read some threads but also had a look on the Whifbitz site. The HKS LA seems like it could be a good option? I also noticed the Spec clutches. They are pretty cheap by comparison, are they any good? The 2+ & 3 are rated to 699lbft and 755lbft respectively, and are ~1/3 the price of the HKS. I presume I'd be as well to change the release bearing and nose bearing while at it? Thanks in advance for any opinions/advice Link to comment Share on other sites More sharing options...
Scott Posted October 16, 2014 Share Posted October 16, 2014 Are the spec clutches multi-plate? Link to comment Share on other sites More sharing options...
novak Posted October 17, 2014 Share Posted October 17, 2014 I would change the end crank seal as well. Link to comment Share on other sites More sharing options...
Lee P Posted October 17, 2014 Share Posted October 17, 2014 What power and torque will you be running The spec clutches are very good and also the HKS LA We generally use the stage 1 spec as it drives as close to stock as you can get, for bigger power the HKS We use both and I keep them both in stock Link to comment Share on other sites More sharing options...
James Posted October 17, 2014 Author Share Posted October 17, 2014 Are the spec clutches multi-plate? The initial models I looked at aren't, they do multi plate clutches though. I would change the end crank seal as well. What power and torque will you be running The spec clutches are very good and also the HKS LA We generally use the stage 1 spec as it drives as close to stock as you can get, for bigger power the HKS We use both and I keep them both in stock I'd want something capable of ~700bhp/700lbft to give me some space. I'd imagine the torque to be more around 580 or such, but if I futureproof it a little I'd be happy Link to comment Share on other sites More sharing options...
Luxluc Posted October 17, 2014 Share Posted October 17, 2014 700tq is alot for a single plate mate. Link to comment Share on other sites More sharing options...
Lee P Posted October 17, 2014 Share Posted October 17, 2014 700ftlbs is a lot of torque for a supra and you would be unlikely to be running that unless running a lot more power. Whet you do want to do is get a clutch to run loads of torque that then doesn't drive very nice and you end up not running anywhere near it The HKS LA twin plate is one of the nicest clutches I've ever used and will do 600ftlbs no problem but its max rating is slightly higher. If your wanting to hold more then maybe an RPS or exeddy tripple carbon would be better. Also depends on budget though The initial models I looked at aren't, they do multi plate clutches though. I'd want something capable of ~700bhp/700lbft to give me some space. I'd imagine the torque to be more around 580 or such, but if I futureproof it a little I'd be happy Link to comment Share on other sites More sharing options...
Luxluc Posted October 17, 2014 Share Posted October 17, 2014 +1 for the RPS triple carbon. Costy, but a great clutch. Link to comment Share on other sites More sharing options...
DaveR Posted October 17, 2014 Share Posted October 17, 2014 Avoid the RPS twin plate is the only value I can add to this - 2 years in and I STILL can't get on with it. I've heard the triple plate is much more user-friendly though. Good luck! Link to comment Share on other sites More sharing options...
Lee P Posted October 17, 2014 Share Posted October 17, 2014 Avoid the RPS twin plate is the only value I can add to this - 2 years in and I STILL can't get on with it. I've heard the triple plate is much more user-friendly though. Good luck! You are right twin plate was never as nice, tripple is the one to have Any carbon clutch isn't going to be perfect for the road tbh which is why the HKS is perfect as an inbetween The carbon is great for big power though and drag racing Link to comment Share on other sites More sharing options...
Sukhy Posted October 17, 2014 Share Posted October 17, 2014 My Carbonetic twin plate (new design) is really easy to use and is not stiff at all. Just a little noisy. Link to comment Share on other sites More sharing options...
Luxluc Posted October 17, 2014 Share Posted October 17, 2014 You are right twin plate was never as nice, tripple is the one to have Any carbon clutch isn't going to be perfect for the road tbh which is why the HKS is perfect as an inbetween The carbon is great for big power though and drag racing My RPS triple CC is very nice like Lee says. The only negative comment will be that the biting point is very narrow; this makes red light starts in an uphill road sometimes slightly more difficult. But all in all, I have been using mine for 5000 mls now, and I would never install anything else. Link to comment Share on other sites More sharing options...
Jellybean Posted October 17, 2014 Share Posted October 17, 2014 OsGiken Street master or the triple http://www.rhdjapan.com/os-giken-street-master-clutch-kit-twin-metal-hard-with-converter-kit.html http://www.rhdjapan.com/os-giken-r3c-multi-plate-racing-clutch-kit.html Link to comment Share on other sites More sharing options...
James Posted August 19, 2016 Author Share Posted August 19, 2016 Well, I went with the HKS LA twin. 2500 miles later (if that) and the rear crank seal which was replaced as a matter of course has leaked and contaminated the clutch badly. There are now loads of hot spots all over it and it slips at anything about 0.5bar. I think I'm going to go for the RPS Triple and look to cleaning up the HKS one - there is still an alright amount left on the plates. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 20, 2016 Share Posted August 20, 2016 RPS Triple all the way, can be a bit of pig to get into reverse but put it in 3rd first and then it slips straight into reverse. Its never slipped and its a good feel to the peddle even after 5 years or so.. Link to comment Share on other sites More sharing options...
Samurai 20V Posted August 20, 2016 Share Posted August 20, 2016 Is the HKS LA good enough for drag racing at 700ftlbs? Link to comment Share on other sites More sharing options...
Lee P Posted August 20, 2016 Share Posted August 20, 2016 Is the HKS LA good enough for drag racing at 700ftlbs? I wouldn't advise is, carbon clutches are better for drag racing Link to comment Share on other sites More sharing options...
Jellybean Posted August 20, 2016 Share Posted August 20, 2016 Well, I went with the HKS LA twin. 2500 miles later (if that) and the rear crank seal which was replaced as a matter of course has leaked and contaminated the clutch badly. There are now loads of hot spots all over it and it slips at anything about 0.5bar. I think I'm going to go for the RPS Triple and look to cleaning up the HKS one - there is still an alright amount left on the plates. Stick with the HKS you mad scone , why pay $$$ again for RPS, rear crank seal could of went with any clutch Link to comment Share on other sites More sharing options...
Guest Budz86 Posted August 20, 2016 Share Posted August 20, 2016 Is the HKS LA good enough for drag racing at 700ftlbs? Doubt the LA would hold 700ft lbs for long, let alone running it up the strip! Carbon all the way for the abuse and heat it will take on the strip, organics don't like either in moderate to large quantities! Link to comment Share on other sites More sharing options...
Luxluc Posted August 20, 2016 Share Posted August 20, 2016 700 ftlbs is a lot ; you need at least twin carbon imo, even better triple. Link to comment Share on other sites More sharing options...
