Chris Wilson Posted October 21, 2014 Share Posted October 21, 2014 Is there a commercially available exhaust manifold pair for this conversion, or were they one offs? Bonnet mods needed? What gives with the sloping water radiator, will the stock rad and positioning not work? To me that looks a sensible conversion, cheap torque in a fairly modern, fairly fuel efficient motor. Ever seen a s/charged Mercedes V8 conversion done to a MKIV? Thanks for the photo! Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 21, 2014 Share Posted October 21, 2014 Looking at the manifolds they must be bought in as Craigs welding is far superior to that, No bonnet mods, Not sure about the Rad, I very much doubt it needs modifying given the engine's length, is it not an optical illusion maybe? Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 21, 2014 Share Posted October 21, 2014 Never seen a SS Merc engine in a Supra. Seen a Quad turbo 12v Merc in a one off Skyline R34. Link to comment Share on other sites More sharing options...
GSR2007 Posted October 28, 2014 Share Posted October 28, 2014 Sorry if this is a really stupid question but is it possible to build a w58 with better internals or with cost involved are you better off just going with a v160 just want to know is it even possible? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 28, 2014 Share Posted October 28, 2014 A good used Getrag will be far less than upgrading the internals in W58. The only practical upgrade would be to straight cut gears and a dog engagement (no synchromesh). If there is a suitable kit it would be totally impractical in a road car transmission due to noise and the inability to change gear at less than racing snatch changes. Link to comment Share on other sites More sharing options...
GSR2007 Posted October 28, 2014 Share Posted October 28, 2014 A good used Getrag will be far less than upgrading the internals in W58. The only practical upgrade would be to straight cut gears and a dog engagement (no synchromesh). If there is a suitable kit it would be totally impractical in a road car transmission due to noise and the inability to change gear at less than racing snatch changes. thanks for the reply mate plain and simple answer Link to comment Share on other sites More sharing options...
garethr Posted October 29, 2014 Share Posted October 29, 2014 (edited) Isn't the tremec gearbox much larger than the V160 though? Sure I've read that someone on Supraforums tried it, and it wouldn't physically fit in the Supras tunnel.One of the Aussie Soarer gurus developed a Tremec 6-speed conversion. if it wlil fit in a Soarer it will fit in a Supra. The gear ratios might be the problem with the Tremecs. They have really high ratios with double overdrive (to meet the CAFE requirements in the US). Good for a big naturally-aspirated or supercharged V8, not so good behind a little turbo 6. Is there a commercially available exhaust manifold pair for this conversion, or were they one offs? Bonnet mods needed? What gives with the sloping water radiator, will the stock rad and positioning not work? To me that looks a sensible conversion, cheap torque in a fairly modern, fairly fuel efficient motor. Thanks for the photo! Craig's thread from 2010 >>>> http://www.mkivsupra.net/vbb/showthread.php?222367-ls1-supra (with a contribution from some bloke called Chris Wilson ) Edited October 29, 2014 by garethr (see edit history) Link to comment Share on other sites More sharing options...
