s-u-p-r-a Posted October 15, 2014 Share Posted October 15, 2014 Hi Guys Looking at flywheels and just cant pick one.....Can any of you guys recommend the best flywheel to get for a na-t im using a spec 3+ clucth or will be:D:D Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2014 Share Posted October 15, 2014 The flywheel will be dictated by the clutch. Unless they say so I would assume it is for mounting to a stock N/A flywheel, unless the clutch is for a TT engine and six speed box? I do my uprated N/A clutch kit, that is fine with a stock torque level TT engine. In fact you are FAR better using a mild clutch on a W58 transmission, as it's less likely to transmit big shock loads and strip the gears. Quote Link to comment Share on other sites More sharing options...
s-u-p-r-a Posted October 15, 2014 Author Share Posted October 15, 2014 Cheers for the advise, I've already got the clutch..... So do you think this will be too much for my little w58 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2014 Share Posted October 15, 2014 Probably, a lot of people break them with turbo torque. Quote Link to comment Share on other sites More sharing options...
