T14PPA Posted October 15, 2014 Share Posted October 15, 2014 Im doing a single conversion on pauls car and i need a drain pipe but it cant be an fittings. The turbo dont allow it to fit a an fitting due to size. I have the flanges but need a hose to push on. What material would i need for this as the temperature will be very high Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted October 15, 2014 Share Posted October 15, 2014 I've got some stainless braided hose left from doing my oil return Mike. I got a metre of it, and didn't even use half. You're welcome to it if it helps? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted October 15, 2014 Share Posted October 15, 2014 Maybe something like this you need to run a -10 fitting? Also it will be alot safer than a push on fitting even if it is low pressure as I used to still get leaks with a push on. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted October 15, 2014 Author Share Posted October 15, 2014 I've got some stainless braided hose left from doing my oil return Mike. I got a metre of it, and didn't even use half. You're welcome to it if it helps? Gaz your always a big help. If you dont mind ill buy it gary. Just hope its long enough Quote Link to comment Share on other sites More sharing options...
T14PPA Posted October 15, 2014 Author Share Posted October 15, 2014 Maybe something like this you need to run a -10 fitting? Also it will be alot safer than a push on fitting even if it is low pressure as I used to still get leaks with a push on. It just wont work Kaan. Theres only a very small space and the an fitting was not even close to fitting Quote Link to comment Share on other sites More sharing options...
Kaan W Posted October 15, 2014 Share Posted October 15, 2014 Damn!! I didn't post the link Here mate - http://www.garagewhifbitz.co.uk/garage-whifbitz-673.html Quote Link to comment Share on other sites More sharing options...
T14PPA Posted October 15, 2014 Author Share Posted October 15, 2014 Damn!! I didn't post the link Here mate - http://www.garagewhifbitz.co.uk/garage-whifbitz-673.html That might work mate thanks alot Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted October 15, 2014 Share Posted October 15, 2014 No charge mate, happy to help Quote Link to comment Share on other sites More sharing options...
T14PPA Posted October 16, 2014 Author Share Posted October 16, 2014 No charge mate, happy to help For now gary keep it im going to try what kaan said first but ill let you know if i need it. Thanks as always Quote Link to comment Share on other sites More sharing options...
TT Paul Posted October 16, 2014 Share Posted October 16, 2014 thanks for the help with this chaps:salute: Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted October 16, 2014 Share Posted October 16, 2014 Take a look at this.. http://www.ebay.co.uk/itm/ford-sierra-escort-cosworth-2wd-4wd-turbo-t3-t34-oil-drain-tube-/371163365685?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item566b0f8135 Quote Link to comment Share on other sites More sharing options...
T14PPA Posted October 16, 2014 Author Share Posted October 16, 2014 I found a weld on extended fitting ive ordered Quote Link to comment Share on other sites More sharing options...
