Toad immobiliser help
coza
Hi
So I was going to move my car to the garage the other day and when I went to start it up the starter motor was sticking so after a few attempts to start the car up my battery went flat just as it was about to start , so I attached the jump leads and that's it
Immobiliser isn't working can't get the battery icon to appear ??? Any ideas ?
Take the battery out, give it a proper charge. Put it back in once its fulled charged, disconnecting the battery should also reset the device. I used to get the same problem, after leaving the negative terminal off for a while, it used to work - bad ground in my case I think.
Last time I had a flat battery I took the thing out to charge it, put it back in and the immobiliser / alarm etc just worked straight away! I have a toad immobiliser/alarm too :)
I think I read on here that it was advisable to disconnect the battery completely rather than charge it whilst its still connected.
So took the battery of and left it of for the night connected it the morning after and nothing , the alarm is a sterling one checked the fuse on the actual box and it was fine I'm out of ideas , the alarm works fine just can't get the immobiliser to work , anyone got any ideas ?
