Al Massey Posted October 14, 2014 Share Posted October 14, 2014 So, this mainly started this morning and it's got me baffled. Symptoms. A few days ago, steering started to get hard, but was intermittent. This morning, every time I move the steering wheel for a turn, steering goes hard and the red oil light comes on then extinguishes. Once warm it's fine. I pulled over, checked oil, looked low, went to top up but only had 0.5 litres in can so drove to garage. Problem seemed to disappear, checked oil, all was fine. Check power steering reservoir and was full, however fluid is very dark. Bought some just in case. Left work, same symptoms until warm and then disappeared. Got home, and whilst still running and very hot, turn wheel and it becomes very hard and same light comes on. Let go of wheel and it extinguishes. (Video below) Check power steering reservoir again, still full but this time it appears to be bubbling, like if something was boiling or air was in the system. (Video below) Recent history. Within the past few weeks I've done a bit of work. 4 weeks ago - Fitted a turbo blanket 3 weeks ago - Changed spark plugs 2 week ago - Made and fitted air filter shield 1 week ago - Removed bumper due to catching it on a kerb, whilst off I removed the inter cooler and pipes for a clean, noticed the radiator was extremely dirty so washed off, no pressure, and the fan that sits in front of the AC condenser was hanging off, so removed it but cut the wires in the process, didn't think much to it as I was removing it. Had to undo and move the power steering pipes out of the way but placed back. Every since that the steering has been intermittent and got worse today. Sorry for the big write up, just trying to be as thorough as possible with all details on the off chance it's something I did. Videos Steering and oil light https://vimeo.com/108924037 Power steering fluid bubbling https://vimeo.com/108924277 General video of engine running/idling with possible hunting? https://vimeo.com/108924363 Link to comment Share on other sites More sharing options...
Al Massey Posted October 14, 2014 Author Share Posted October 14, 2014 No one can help? Link to comment Share on other sites More sharing options...
jagman Posted October 14, 2014 Share Posted October 14, 2014 In the first instance clean the filter - it's like a Brillo pad inside the reservoir , this gets clogged and stops fluid getting to the pump , hence no return flow (bubbles) To clean the filter you need to take the reservoir off and fill /shake with a solvent , it's a good time to replace the fluid too . I've had this on 3 cars each time it cured the problem , bonus , as it's the cheapest too . Link to comment Share on other sites More sharing options...
Al Massey Posted October 15, 2014 Author Share Posted October 15, 2014 In the first instance clean the filter - it's like a Brillo pad inside the reservoir , this gets clogged and stops fluid getting to the pump , hence no return flow (bubbles) To clean the filter you need to take the reservoir off and fill /shake with a solvent , it's a good time to replace the fluid too . I've had this on 3 cars each time it cured the problem , bonus , as it's the cheapest too . Cheers, I will give that a try tomorrow Link to comment Share on other sites More sharing options...
wile e coyote Posted October 15, 2014 Share Posted October 15, 2014 Be carefull when refitting as you can pinch the oil ring Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2014 Share Posted October 15, 2014 What "oil light" comes on? I would check carefully which light is really coming on, and also do the Tipex test on the crank damper outer pulley. I suspect it's come unbonded. Link to comment Share on other sites More sharing options...
tattoosamy Posted October 15, 2014 Share Posted October 15, 2014 Vaccum leak? Link to comment Share on other sites More sharing options...
Al Massey Posted October 15, 2014 Author Share Posted October 15, 2014 What "oil light" comes on? I would check carefully which light is really coming on, and also do the Tipex test on the crank damper outer pulley. I suspect it's come unbonded. It's funny you should mention that. It is the red oil light far right one, that is oil pressure? I broke down this morning, no charge from alternator, AA have came out and on closer inspection it does look like the crank damper has failed, as when turning the wheel, the pulleys seem to slow down. So maybe the alternator hasn't gone and it's just the crank damper failing so no turning fast enough. I'm guessing your thoughts would be the same? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 15, 2014 Share Posted October 15, 2014 Sounds like crank pulley failure yep. Link to comment Share on other sites More sharing options...
Al Massey Posted October 15, 2014 Author Share Posted October 15, 2014 Sounds like crank pulley failure yep. Great lol How much you do them for Paul? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2014 Share Posted October 15, 2014 The light that may have come on was a no charge light, but Supra dash displays do odd things with low voltage input. Needs a new damper, I see Paul is here, he's the man for discounted ones. Jerky power steering is one of the ways a slipping crank damper drive pulley manifests itself. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 15, 2014 Share Posted October 15, 2014 http://www.garagewhifbitz.co.uk/toyota/supra/engine-components/pulleys-belts/toyota-1073.html loads in stock, Link to comment Share on other sites More sharing options...
Al Massey Posted October 15, 2014 Author Share Posted October 15, 2014 The light that may have come on was a no charge light, but Supra dash displays do odd things with low voltage input. Needs a new damper, I see Paul is here, he's the man for discounted ones. Jerky power steering is one of the ways a slipping crank damper drive pulley manifests itself. Cheers. Well I'm glad it broke down before the damper went flying. And really glad for this forum http://www.garagewhifbitz.co.uk/toyota/supra/engine-components/pulleys-belts/toyota-1073.html loads in stock, Cheers Paul Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 15, 2014 Share Posted October 15, 2014 Cheers. Well I'm glad it broke down before the damper went flying. And really glad for this forum Cheers Paul Yep, we've seen radiators, radiator shrouds, engine covers, water pumps all destroyed when the pulleys let go! Link to comment Share on other sites More sharing options...
Al Massey Posted October 15, 2014 Author Share Posted October 15, 2014 Yep, we've seen radiators, radiator shrouds, engine covers, water pumps all destroyed when the pulleys let go! Ouch Just waiting for my mrs credit card details so I'll be ordering one asap Link to comment Share on other sites More sharing options...
Al Massey Posted October 15, 2014 Author Share Posted October 15, 2014 New crank damper ordered cheers Paul Will start stripping the car tonight Link to comment Share on other sites More sharing options...
