Mad Hatter Posted October 14, 2014 Share Posted October 14, 2014 I've bought a new rad since mine left me stranded on Sat night .. top up and drive 4 miles .. top up and drive 4 miles ... no fun. Is the rad difficult to swap over? 94' TT auto. I know it has the gearbox cooler in the bottom etc.. I just wondered if anyone has a step by step guide to replacing it or whether you should just throw it into the garage? cheers all Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 14, 2014 Share Posted October 14, 2014 It is easy and will take an 1/2 hours max. Remove the shroud ( 10mm bolts) Undo all 4 hoses ( 2 large water & 2 small auto ) Undo the sensors at the bottom Undo the top two rad clamps Lift out the radiator Do reverse to re-fit Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted October 14, 2014 Author Share Posted October 14, 2014 so the bumper can stay on? any recommendation on the fluids to use for the auto box? Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 14, 2014 Share Posted October 14, 2014 Yes bumper can stay on, and I didnt need to replace any fluids as the level didnt drop enough Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted October 14, 2014 Author Share Posted October 14, 2014 the voice of experience .. right i'll crack on then! Cheers Matt! Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted October 14, 2014 Share Posted October 14, 2014 (edited) Its worth doing the thermostat and changing fluids, if your pipes are old then worth changing them too mate. I did the job and im a rook, needed a hand lifting it out. There is a guide I think on the main page, its the workshop manual Edited October 14, 2014 by supra_ufo (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted October 14, 2014 Share Posted October 14, 2014 http://www.mkivsupra.net/vbb/content.php?60-Cooling-System Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted October 14, 2014 Author Share Posted October 14, 2014 Nice one, thanks Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted October 23, 2014 Author Share Posted October 23, 2014 It is easy and will take an 1/2 hours max. Remove the shroud ( 10mm bolts) Undo all 4 hoses ( 2 large water & 2 small auto ) Undo the sensors at the bottom Undo the top two rad clamps Lift out the radiator Do reverse to re-fit Half hour job max ... took 4 hours. granted the shroud took 2hrs to get it off and get new ones, then bracket bits to fit the new rad. The new rad is a bit thicker and need a lump chopped out of the battery tray to get it back in. It fits .. but a bit of a squeeze finished in the dark with only a torch in my gob to see what the hell I was doing haha Well worth it though as you may see *yuk* http://springboxconsulting.com/images/supra/oldrad4.jpg Quote Link to comment Share on other sites More sharing options...
mattdavies Posted October 23, 2014 Share Posted October 23, 2014 Maybe I was a little optimistic, simple enough job though all being well. Glad you got it sorted. Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 23, 2014 Share Posted October 23, 2014 Did you check the cross member that the rad sits on ? They're quite prone to rotting but if caught soon enough can be a straight forward fix Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted October 23, 2014 Author Share Posted October 23, 2014 It was pitch black at 8pm when I got to the point of fitting the new one. Had to use my Land Rover headlights just to see wtf I was holding. Everything looks fine underneath and the mounts were surprisingly clean and not brittle. I've just picked up the new condenser so I'm going to have to get the rad off again soon to get this in. All being well Matt with parts that fit and day light, you were quite right, I could do the next one in half an hour lol Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 23, 2014 Share Posted October 23, 2014 A couple of pics showing the rot Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted October 23, 2014 Author Share Posted October 23, 2014 Thanks Dnk, I'll Go looking. Quote Link to comment Share on other sites More sharing options...
