Jellybean Posted October 14, 2014 Share Posted October 14, 2014 (edited) Hey Car ODO is 135000 KM ,T belt Last done 85000 KM I want to replace the Tbelt , Vbelt and Crank pulley ; let me know if i am missing anything from the List or things I dont need:) Thanks Timing Belt Timing Belt Tensioner Bearing & Bracket Timing Belt Hydraulic Tensioner ABSORBER SUB-ASSY, BELT TENSIONER ( I need this, mine is fubar ) AUX BELT 16620 TENSIONER ASSY, V-RIBBED BELT 16621 BRACKET, V-RIBBED BELT TENSIONER ? I think aftermarket guys try to get you to replace this with a billet item Crank Pulley 13521P CRANKSHAFT TIMING Sprocket (pulley) ? 11011 WASHER SET, CRANKSHAFT THRUST? 13566A GUIDE, TIMING BELT? Crankshaft Bolt? Edited October 14, 2014 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted October 14, 2014 Share Posted October 14, 2014 You shouldn`t need the last 3 items on your list:) Quote Link to comment Share on other sites More sharing options...
jonc Posted October 14, 2014 Share Posted October 14, 2014 Hey Car ODO is 135000 KM ,T belt Last done 85000 KM I want to replace the Tbelt , Vbelt and Crank pulley ; let me know if i am missing anything from the List or things I dont need:) Thanks Timing Belt Timing Belt Tensioner Bearing & Bracket Timing Belt Hydraulic Tensioner ABSORBER SUB-ASSY, BELT TENSIONER ( I need this, mine is fubar ) AUX BELT 16620 TENSIONER ASSY, V-RIBBED BELT 16621 BRACKET, V-RIBBED BELT TENSIONER ? I think aftermarket guys try to get you to replace this with a billet item Crank Pulley 13521P CRANKSHAFT TIMING Sprocket (pulley) ? 11011 WASHER SET, CRANKSHAFT THRUST? 13566A GUIDE, TIMING BELT? Crankshaft Bolt? In my opinion buddy this is what I changed when I did mine last year (TT VVTI) Auxy belt- Timing belt - I used a Gates belt Timing belt tensioner 13540-46012 Timing belt idler 13505-46041 Tensioner assembly 16620-0W024- I have the metal wheel version and my tensioner was fine but my bearing was whining so I just changed the bearing Water pump 16100-49846 Crank damper 13407-46020. I didn't replace mine so the original is still on there but with the fight to get it off it makes sense to replace it if you can afford it. I didn't need an absorber and I re used the crankshaft bolt. I cannot see the need to change the timing belt guide, crank pulley or thrust washer as all these items were good and don't wear as far I can see. I did my oil pump at the same time with the engine in the car so obviously needed a lot more stuff to do with that job but I think that covers what I can remember for the timing belt. I made my own special tools for the crank locking tool, crankshaft pulley puller and crank damper. I would also add in that I tapped out all the M8 holes be in the damper before I pulled it as they get full of crud. The worst part about the job was getting that crank bolt undone:eyebrows: Some others may come along with more info but Marks how to was easy to follow http://www.mkivsupra.net/vbb/showthread.php?65774-How-To-Change-the-cambelt-(93-J-Spec-TT-Auto)&highlight=crank+pulley+bolt For ease of access I did strip off everything around the front of the engine including the alternator (to get to the timing belt tensioner bolts). Hope this helps a bit Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted October 15, 2014 Share Posted October 15, 2014 Just order timing belt kit + water pump, the kit comes with tensioner & guide pulley. Also order aux belt + tensioner & it would be worth getting a new crank pulley while your at it. You'll also need coolant as you will be doing the water pump. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted October 31, 2014 Author Share Posted October 31, 2014 As I am doing the Crank pulley I was advised to do the crank shaft seal What is the part number for that? I cannot see anything with Shaft seal in the description , is it the trust washer? 11011 Quote Link to comment Share on other sites More sharing options...
Iky Posted October 31, 2014 Share Posted October 31, 2014 is it the trust washer? 11011 No, it's not that. I'll dig out the number for you. Quote Link to comment Share on other sites More sharing options...
Iky Posted October 31, 2014 Share Posted October 31, 2014 It's 90311-46001 under the oil pump section on Toyodiy Quote Link to comment Share on other sites More sharing options...
Jellybean Posted October 31, 2014 Author Share Posted October 31, 2014 It's 90311-46001 under the oil pump section on Toyodiy thanks! Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 31, 2014 Share Posted October 31, 2014 Get the oil pump/crank seal off Chris Wilson Quote Link to comment Share on other sites More sharing options...
Jellybean Posted October 31, 2014 Author Share Posted October 31, 2014 Get the oil pump/crank seal off Chris Wilson ? how come , I dont need an oil pump, was going to wait till it goes Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 31, 2014 Share Posted October 31, 2014 (edited) I didn't mean get the oil pump i meant the seal, it sits in the pump. CW sells uprated ones incase your crank has some wear on it where the seal sits In addition waiting for the oil pump to fail is a real bad idea ! Edited October 31, 2014 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted October 31, 2014 Author Share Posted October 31, 2014 I didn't mean get the oil pump i meant the seal, it sits in the pump. CW sells uprated ones incase your crank has some wear on it where the seal sits In addition waiting for the oil pump to go is a real bad idea ! Thanks , Just going on advise of my mechanic , my car has 158K KM in the clock, as far as I know oil or water pump was never done He says I am being anal doing them Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 31, 2014 Share Posted October 31, 2014 Yes he's probably right, my car had done 137,000 miles and the oil pump was fine. I'd test to see what pressure its putting out now Quote Link to comment Share on other sites More sharing options...
Jellybean Posted October 31, 2014 Author Share Posted October 31, 2014 Yes he's probably right, my car had done 137,000 miles and the oil pump was fine. I'd test to see what pressure its putting out now Cool, thanks Will drop Chris an email for the seal if he says leave them alone Thanks Dunk Quote Link to comment Share on other sites More sharing options...
Jellybean Posted October 31, 2014 Author Share Posted October 31, 2014 So Final List is Am I missing Anything? SEAL(FOR CRANKSHAFT) 90311-46001 Power Enterprise Kevlar Tbelt TENSIONER ASSY, CHAIN, NO.1 13540-46011 IDLER SUB-ASSY, TIMING BELT, NO.1 13505-46041 ABSORBER SUB-ASSY, BELT TENSIONER 16602-46010 Water Pump + Housing 16100-49845 Oil pump,PUMP ASSY, OIL 15100-46051 RING, O(FOR OIL PUMP) No.1 96721-24022 RING, O(FOR OIL PUMP) No.2 96721-24031 Unorthodox Racing Idler Pulley Unorthodox Racing Lightened Pulley Set^ Titan ATI Crank Pulley Quote Link to comment Share on other sites More sharing options...
