Geo Posted October 13, 2014 Share Posted October 13, 2014 So getting to the stage now where i've got the crank pulley to pop off, pistons and crank out then its time to clean all the parts. Is there anything i should consider when i send off to the Place that will clean it in the tank? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 13, 2014 Share Posted October 13, 2014 Remove all block core plugs, and oil gallery plugs, steam out all block, crank and head oilways, get the parts hot enough their absorbed heat will self dry them fast, then spray with WD40, wrap and store. Hot tanking will *NOT* clean out oilways. If the engine has crank bearing damage and shrapnel in it, bin the Modine and any associated engine oil cooler matrix. If it has overheated get the head casting hardness tested, and tested for warpage. If it's warped it's probably scrap. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted October 13, 2014 Share Posted October 13, 2014 A timely thread....what are the company going to do when cleaning it Geo? I was thinking of getting mine cleaned in an ultrasonic bath Quote Link to comment Share on other sites More sharing options...
Geo Posted October 13, 2014 Author Share Posted October 13, 2014 Remove all block core plugs, and oil gallery plugs, steam out all block, crank and head oilways, get the parts hot enough their absorbed heat will self dry them fast, then spray with WD40, wrap and store. Hot tanking will *NOT* clean out oilways. If the engine has crank bearing damage and shrapnel in it, bin the Modine and any associated engine oil cooler matrix. If it has overheated get the head casting hardness tested, and tested for warpage. If it's warped it's probably scrap. thanks chris will take this to the company that i might use, i have a good engine, only thing so far iv seen it a gasket that been in bits at the thermostat area. will get a good look inside block once i get crank pulley off. A timely thread....what are the company going to do when cleaning it Geo? I was thinking of getting mine cleaned in an ultrasonic bath looking into it just now bud, the ultrasonic cleaning looks awesome and to me looks best, but a tank looks just as good. i'll do some more digging about my area as i dont wana send it away, id rather be local and watch them do it tbh Quote Link to comment Share on other sites More sharing options...
