Ibrar Jabbar Posted October 11, 2014 Share Posted October 11, 2014 Been having a few problems with the Supra starting lately. Ryan diagnosed a faulty wideband sensor and noise on air temp, fuel pressure and oil pressure sensors. I have since replaced the wideband sensor and fitted a much thicker earth lead as advised. I have also changed all HT leads and plugs as I was getting misfire (that is now cured and the wideband is working). Ashley from SRD went through a few things with me on how to check gauges, logs, etc using the Syvecs software, however I can't get my head around it and was wondering if anybody could have a check using teamviewer to access my laptop and see if there is any other faults as the car struggles to start when cold. Failing that if anybody could have a check for me at Santapod tomorrow? All help appreciated. Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 11, 2014 Share Posted October 11, 2014 Lee or Wez will be your best bet if you can't get Ryan to do it mate. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted October 11, 2014 Author Share Posted October 11, 2014 Lee or Wez will be your best bet if you can't get Ryan to do it mate. Can't get hold of Ryan till next week, getting no answer on Lee's landline. I Don't have a contact number for Wez. Quote Link to comment Share on other sites More sharing options...
Lee P Posted October 11, 2014 Share Posted October 11, 2014 Can't get hold of Ryan till next week, getting no answer on Lee's landline. I Don't have a contact number for Wez. Not had any calls this afternoon unless you rang this morning Im going out soon so could do it now Quote Link to comment Share on other sites More sharing options...
Lee P Posted October 11, 2014 Share Posted October 11, 2014 Did you change the coil packs as well? They will probably be the missfire Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted October 11, 2014 Author Share Posted October 11, 2014 Ah just seen this it's ringing out again (01444 616771). Coilpacks are OK as the misfire went with the plug change. Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 11, 2014 Share Posted October 11, 2014 I text you Lee and Wez's mobile numbers mate. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted October 11, 2014 Author Share Posted October 11, 2014 Thanks Jamie. Big thanks to Lee for making some adjustments. It seems much better now, but will know for sure after tomorrow's run to the Pod. Quote Link to comment Share on other sites More sharing options...
