ShawnPreece Posted October 9, 2014 Share Posted October 9, 2014 (edited) Hi I'm currently fitting a HKS type 1 turbo timer in my supra, my supra started life as a manual non turbo but has had an engine swap and had a vvti twin turbo put into it. Iv put the HKS wiring harness in and am currently trying to connect the RPM signal wire and the Speed signal wire into the Ecu... The wiring diagram iv got doesn't seem to match up with the ECU (see pic) this is the 1st time iv done any wiring towards the ECU so just want to ask if it's just that it's a non turbo ECU and wiring is different although iv googled wiring diagram for non turbo ECU and still looks different or if I'm just being dumb and have missed something? Edited October 9, 2014 by ShawnPreece Accidentally pressed go half way through (see edit history) Link to comment Share on other sites More sharing options...
David P Posted October 9, 2014 Share Posted October 9, 2014 Pins shown towards bottom of page. http://www.jegs.com/InstallationInstructions/0/017/017-30-1100.pdf Link to comment Share on other sites More sharing options...
ShawnPreece Posted October 9, 2014 Author Share Posted October 9, 2014 Or even if it has had a ECU swap and is a TT ECU and I'm just missing something... Link to comment Share on other sites More sharing options...
ShawnPreece Posted October 9, 2014 Author Share Posted October 9, 2014 Pins shown towards bottom of page. http://www.jegs.com/InstallationInstructions/0/017/017-30-1100.pdf Ahh awesome thanks, I'm still confused as to which connectors they are though as doesn't seem to be 3 connectors that look the same as on the wiring diagram? Not sure if I'm just being stupid or not Link to comment Share on other sites More sharing options...
David P Posted October 9, 2014 Share Posted October 9, 2014 A VVTI engine requires a VVTI ECU. Post a pic, then we can see what your on about. Link to comment Share on other sites More sharing options...
ShawnPreece Posted October 9, 2014 Author Share Posted October 9, 2014 Ahh I see yeah the that would be why the connector pattern looks different then, here's a pic of my ECU... Thanks for your help il try and find a vvti ECU wiring diagram Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 9, 2014 Share Posted October 9, 2014 You have a VVTI ecu so those diagrams are useless. Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 9, 2014 Share Posted October 9, 2014 Try this instead. http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf TACH is the rpm signal (Pin 20 of Connector B77 (G) - Black/White) and SPD is the speed signal (Pin 25 of Connector B77 (G) - Pink). Link to comment Share on other sites More sharing options...
ShawnPreece Posted October 9, 2014 Author Share Posted October 9, 2014 After a lot of searching I have now found the correct diagram that I'm after Incase anyone is after a pinout diagram for a VVTI ECU the link below and the screenshots is what your after: http://http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf Here are my screenshots off he above link if it's easier to go off: - - - Updated - - - Try this instead. http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf TACH is the rpm signal (Pin 20 of Connector B77 (G) - Black/White) and SPD is the speed signal (Pin 25 of Connector B77 (G) - Pink). I just found the same thing lol, thankyou for your help though Link to comment Share on other sites More sharing options...
