icio471 Posted October 7, 2014 Share Posted October 7, 2014 Hello guys, today i decided to do an uprated on my supra . Dash pannels was very bad so decided to repaint it from white to black. speedometer has the old yellow lights so decided to go in a shop and buy new whitte led lights. put the new lights but suprise... when lights are on odomoter is off... ok no problem i thought in a first moment. Try again with the original like in origin and fuck... it's the same... so now i have the original speedodometer with original lights that is off but if i turn the key in second position work only master stop,handbrake stop and if i try the arrows... so... what fuck is happend?? i'm very angry now ,this car has a lot problems with wirings , isn't the first time that i have one, infact after this , i discovered a new surprise connecting the odo... turn the lights bottom and disappear the total amount of the km... i don't know how i have to do. any advice for me?some similiar experience? i have also the small box 3 cmx2cm that you use to convert kph to mph and i think that this could be a problem now... do you think that is a solution start to remake the original configuration and take off this small box?.... Please help me is impossible i removed the speedometer in 2 years 4 5 times... and this is the first time that happend this. I want to say you that speedometer work correctly but is a problem only for the lights........ Quote Link to comment Share on other sites More sharing options...
David P Posted October 7, 2014 Share Posted October 7, 2014 It looks like you've mended it till you broke it. Test each wire where you've been until you find it. Quote Link to comment Share on other sites More sharing options...
