supra joe Posted October 7, 2014 Share Posted October 7, 2014 Anyone know ? It's just turning... Link to comment Share on other sites More sharing options...
safcdixon Posted October 7, 2014 Share Posted October 7, 2014 (edited) You have to lock it off with a bar bolted to the pulley, that gets locked against the chassis leg, then you use the starter to fire it over and it undoes the bolt iirc, theres a how to on here somewhere Joe but I cant for the life of me find it btw Ive never done it, just what ive read on here Edited October 7, 2014 by safcdixon (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted October 7, 2014 Share Posted October 7, 2014 (edited) If you use the starter motor method you dont bolt a bar to the pulley, you wedge the breaker bar under the chassis rail, best to pull a fuse so the engine wont start then flick the ignition on the key engaging the starter thus undoing the nut. I prefer to lock the pulley and then undo the nut properly but to do this you will need a special tool that you bolt to the pulley. Edited October 7, 2014 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
trebor69 Posted October 7, 2014 Share Posted October 7, 2014 I lay under the car holding a socket and extension bar against the ground and my girlfriend flicked the ignition, do not turn over and over etc just a click is enough. Link to comment Share on other sites More sharing options...
trebor69 Posted October 7, 2014 Share Posted October 7, 2014 I lay under the car holding a socket on the bolt and an extension bar against the ground and my girlfriend flicked the ignition, do not turn over and over etc just a click is enough. Link to comment Share on other sites More sharing options...
supra joe Posted October 7, 2014 Author Share Posted October 7, 2014 Cool thanks guys, hodge is going to lend me the tool I need to get it off. Thanks for the advice Link to comment Share on other sites More sharing options...
Fizzy T Posted October 7, 2014 Share Posted October 7, 2014 I was going to say use the starter and a breaker bar trick but regardless you'll need a locking tool to do the nut back up to torque. Link to comment Share on other sites More sharing options...
