How to undo the crank pulley ?
supra joe
You have to lock it off with a bar bolted to the pulley, that gets locked against the chassis leg, then you use the starter to fire it over and it undoes the bolt iirc, theres a how to on here somewhere Joe but I cant for the life of me find it
btw Ive never done it, just what ive read on here
Edited by safcdixon (see edit history)
If you use the starter motor method you dont bolt a bar to the pulley, you wedge
the breaker bar under the chassis rail, best to pull a fuse so the engine wont start
then flick the ignition on the key engaging the starter thus
undoing the nut.
I prefer to lock the pulley and then undo the nut properly but to do this you will
need a special tool that you bolt to the pulley.
