Kaan W Posted November 1, 2014 Share Posted November 1, 2014 Looks spot on, much better than before. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 9, 2014 Author Share Posted November 9, 2014 Decided I was having too much fun with the Supra, so decided to myself sad by taking all the dash out again to fix the heater Started a bit late in the afternoon, so I just managed to get the crash bar & heater unit out as the sun went down. Assuming it's not chucking it down tomorrow, I can hopefully get everything back in again in record time. Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 9, 2014 Share Posted November 9, 2014 Well atleast i know if mine ever needs changing i can know a couple of people that can help..... Quote Link to comment Share on other sites More sharing options...
clay Posted November 9, 2014 Share Posted November 9, 2014 your car looked good at bluewater mate. Quote Link to comment Share on other sites More sharing options...
Abz Posted November 10, 2014 Share Posted November 10, 2014 (edited) You'll now be expert level at Supra dash removing Here is a picture I took of both our cars together at Bluewater. Edited November 10, 2014 by Abz (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 10, 2014 Share Posted November 10, 2014 That's what I was after really came up nice. One more cut back and it should be done Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 11, 2014 Author Share Posted November 11, 2014 I'm well annoyed. Adjusted the heater and made sure the pipes were as solid as I could make them to ensure they wouldn't move around. Put everything back in and still getting a bloody leak in the passenger footwell. Whoever designed the heater should be shot, can't believe they don't use proper fittings to make sure the pipes stay tight around the heater radiator. Anyway I give up for the time being, will just block the heater off again till I come up with a better idea to get it working. Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 12, 2014 Share Posted November 12, 2014 Gutted mate. Maybe get a few pairs of eyes on it next time? Kaan has had his out before maybe worth an ask. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 12, 2014 Share Posted November 12, 2014 I'm well annoyed. Adjusted the heater and made sure the pipes were as solid as I could make them to ensure they wouldn't move around. Put everything back in and still getting a bloody leak in the passenger footwell. Whoever designed the heater should be shot, can't believe they don't use proper fittings to make sure the pipes stay tight around the heater radiator. Anyway I give up for the time being, will just block the heater off again till I come up with a better idea to get it working. Did the pipes have good condition o-rings between the fittings on the top of the heater box? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 12, 2014 Author Share Posted November 12, 2014 (edited) Did the pipes have good condition o-rings between the fittings on the top of the heater box? Yeah I used the new ones that came with the new matrix and made sure when putting them back in that everything was sitting as solid as it could have been. Next time I take everything out I'll check the radiator for leaks on the off chance it's down to that. It sound a little extreme but I might get a friend to weld the pipes onto the heater box fittings, no chance of leaks or movement then. Edit: Actually that probably won't work as I would like it to as the heater inlet connects to the water valve, which probably isn't made of metal. Grrr Edited November 12, 2014 by Mike2JZ (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 12, 2014 Share Posted November 12, 2014 Is it possible to run it with all the dash out? just connect enough? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 20, 2014 Author Share Posted November 20, 2014 Picked up a whole new heater unit from monkey3, which feels a lot more solid by the heater matrix then what I currently have, so I've got faith this will work! Hopefully fit it in this weekend and enjoy having the windows up for once. Also a quick external mic soundcheck on my way home: The exhaust sounds is obviously missing boost, but it sounds quite throaty with the pedal down, so will get some more clips in future. Quote Link to comment Share on other sites More sharing options...
Hammer Posted November 20, 2014 Share Posted November 20, 2014 Great work. Your perseverance with the heater will win out in the end I'm sure. Great to see a nice Supra brought back to life and someone enjoying it. Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 20, 2014 Share Posted November 20, 2014 Kepp going mike. Im booked up all weekend or id say bring it over. Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted November 20, 2014 Share Posted November 20, 2014 You could use a sealant over the pipes at the joins? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 20, 2014 Share Posted November 20, 2014 Maybe pop the loom off of the dash this time, conmect it all up and run the car before you bolt it all back together? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 25, 2014 Author Share Posted November 25, 2014 It is done! Started the heater matrix job at 21:45 tonight, finished at 02:00. Dunno about the rest of the UK, but down south it was bitterly cold. Having the heater on for the drive home was the best feeling ever. Gonna go sleep like a baby now. Next up is: - Get sound system in car working - Increase mpg (new 02 sensors + other goodies incoming) Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 25, 2014 Share Posted November 25, 2014 Lmao nice one dude. Give kris a shout about sounds he will sort you out. After I get my dash back in again I should make another meet Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted November 25, 2014 Share Posted November 25, 2014 It is done! Started the heater matrix job at 21:45 tonight, finished at 02:00. Dunno about the rest of the UK, but down south it was bitterly cold. Having the heater on for the drive home was the best feeling ever. Gonna go sleep like a baby now. Next up is: - Get sound system in car working - Increase mpg (new 02 sensors + other goodies incoming) took me 2 weeks on and off and alot of swearing Quote Link to comment Share on other sites More sharing options...
Abz Posted November 25, 2014 Share Posted November 25, 2014 It is done! Started the heater matrix job at 21:45 tonight, finished at 02:00. Dunno about the rest of the UK, but down south it was bitterly cold. Having the heater on for the drive home was the best feeling ever. Gonna go sleep like a baby now. Next up is: - Get sound system in car working - Increase mpg (new 02 sensors + other goodies incoming) You are like an expert on dash removal Well done on getting it fixed, most likely the worst thing to do on the car! Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 25, 2014 Author Share Posted November 25, 2014 You are like an expert on dash removal Well done on getting it fixed, most likely the worst thing to do on the car! It's actually not to bad of a job, now that I know it off the top of my heart. Just takes some time, that said hopefully I don't have to take everything out again in the future. Also found out what the issue was with my heater and why it was leaking. When I first received the car, with the heater out, the metal clamps that are meant to be secured to to the water heater pipes & the heater matrix weren't attached. So for the longest time I had no idea that they needed to be attached, which explain why I was always getting leaks whenever running the car. After buying the new heater unit from Monkey3, I noticed immediately that his had the clamps installed and is the reason why it worked first time. There was lots of swearing when I found out the issue was so simple and was down to me overlooking something so small. So I will fix the 'old' heater now, run some leak tests on it and sell it on & update the heater matrix swap guide with a couple of my findings which should hopefully save people doing the same mistake as me. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted November 25, 2014 Share Posted November 25, 2014 Damn how did you not think they needed clamps Glad it's all sorted now mate and turned out to be something simple Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 25, 2014 Share Posted November 25, 2014 Mike. My dash is currently out the car......i never changed the matrix? If you help with your new found skills i will probably buy it from you Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 25, 2014 Author Share Posted November 25, 2014 Mike. My dash is currently out the car......i never changed the matrix? If you help with your new found skills i will probably buy it from you Does it need changing? Quote Link to comment Share on other sites More sharing options...
The Raven Posted November 25, 2014 Share Posted November 25, 2014 Nope, but it is 20 years old im changing the dash loom due to nasty looking wires figured i might aswell swap the matrix Quote Link to comment Share on other sites More sharing options...
