yellow light engine with stop on odometer! help
icio471
Guest jvanovich
It's a lot time that appear this yellow light , while i'm running with the car after some chilometer appear this yellow light but is stopped together with the red stop signal in the odometer.
the car goes like nothing is happened and if you try to go faster there are no problems. All seems ok. any bad changement in the car or strange noises from engine.
I have to have afraid of it? COuld someone give an opinion for experience? the model is 93 NA with whifbitz exhaust and hks induction kit. NO SWAP no other changements at the moment.
Could someone give me a link where to buy the connerctors?
thanks in advance.
Hi i had the same problem with mine. Now i have bigger problems but all started in the same way.
After a while the engine started to missfire. I cleaned the injectors and it worked again for a while and missfired again i took the injectors out again and i fitted them back no cleaning no nothing and it worked for a while again.I didnt used the car for a year not even started for a year. These days i started the car the idle was 2000 RPM missfires and is very noisy. I didnt had the cable too. i changed some parts.
I changed the air sensor, sparkplugs, spark distribuitor and today i changed those rubber rings fron the injectors. now the idle is at 1000 RPM still missfires and missfires are in the intake.
I tried the TE1 with E1 Thing to get a code but nothing happened :(
sorry for my english i am from Romania And sory for posting in this threat.
