Turbo removal while engine still in place ( UK SPEC )
ronttuk
On jspec (and I think uk spec is not much different?) I find it easier to remove the turbos as set from the turbo manifold, I use a spanner with one side cut off so I can slide a pipe over it to remove the lower bolts. Easier when the exhaust valve is removed, can be done though with it in place. I believe I also removed the right subframe bracket (from the alu to steel subframe), to get more workspace below the turbos.
