Lil Posted September 28, 2014 Share Posted September 28, 2014 Hello, It's been a while that I notice A ratle noise coming from the back of the car, It is more noticable when I am using the MANU mode in L around 2-3k rpm. Also on the motorway when I put my foot off the accelerator I can listen to a weird whistle coming from the middle/rear of the car. Last december I fitted a Torsen A01B Diff so the oil on the Diff is pretty much new :/ It is worrying because I think that Torsens doesn't suppose to be noisy ar all.. Any thoughts? Thanks In advance Quote Link to comment Share on other sites More sharing options...
Guest lloydy Posted September 28, 2014 Share Posted September 28, 2014 Have you checked the boot rubbers? they're a common cause of rattles from the back of the car. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted September 28, 2014 Share Posted September 28, 2014 Have you checked the boot rubbers? they're a common cause of rattles from the back of the car. This, sometimes it's worth checking the back box isn't knocking too. Quote Link to comment Share on other sites More sharing options...
Lil Posted September 28, 2014 Author Share Posted September 28, 2014 It sounds like it's unferneath the car but I will check anyway, I already found the parnumber of the rubbers sto I will order them in any case. Quote Link to comment Share on other sites More sharing options...
listy Posted September 28, 2014 Share Posted September 28, 2014 Are your heat shields still in place around the exhaust? If it's loose it can rattle at lower RPM, and the air pushing past it may cause the whistling sound. Boot rubbers only really make noise over bumps etc and I wouldn't expect that to cause a whistle at higher speeds. Quote Link to comment Share on other sites More sharing options...
Lil Posted September 29, 2014 Author Share Posted September 29, 2014 I need to find a ramp and I'll check that mate! thanks! Quote Link to comment Share on other sites More sharing options...
