Tein lowering springs?
Kendo11
Fronts are lower than the rears. Did you have S tech ones Ben or TT ones?
They lower the front 36mm and the rear 42mm according to the advert I've just read. I helped fit some to Josh(42)'s car and parked it side by side with mine (fitted with 40mm lowering springs all round) and his was definitely higher on the front than mine.
I'm surprised that a few mm difference is noticeable but it definitely was. Maybe there are different versions of the Teins?
Edited by Rich.2211 (see edit history)
Depends the Jap ones lower the front 36mm and the rear 20mm iirc. I'm certain there were two types for a NA and the ones you fitted sound for a TT to me.
