Turbo vsv problem
Twin turbo
Hello does anyone know if acturator to intake air control valve (IACV) and exhaust gas control valve (EGCV) will operate during 4000rpm while car is in park/netural? I See no reaction from acturator and wondering if it is normal while car is in neutral or there or there is a problem with the vsv.what could be wrong
Thats good news :)my only issue now is why i have a rough idle at start when engine is cold, it only last a few seconds though and idle is fine 99 percent of the time when engine has normal temperature,exept a little hikkup now and then.have tested that idle control valve makes that click when i stop the engine,or actually sounds more like 3 clicks.my car has only 25000km on the odometer so i belive that there is no deposit inside the valve.
