Si_s Supe Posted September 23, 2014 Share Posted September 23, 2014 I'm changing the radiator on my NA auto at the weekend which obviously means disconnecting transmission oil cooler. Since I'm doing this, I'm going to do a partial ATF change. Never serviced an auto box before so my question is, do I just refill until fluid comes out the fill hole or do I need to top up bit by bit until the level is correct on the dipstick? Link to comment Share on other sites More sharing options...
trebor69 Posted September 23, 2014 Share Posted September 23, 2014 (edited) You will only get around two litres out of the drain plug, then you can replace that two litres with fresh stuff but this must go down the dipstick tube, then whatever you lose in the bottom of rad (cooler) you can replenish by dipping it whilst warm and topping up the same way (dipstick tube) I found it best to wrap plenty of clingfilm around pipe ends when removed. Edited September 24, 2014 by trebor69 (see edit history) Link to comment Share on other sites More sharing options...
Si_s Supe Posted September 24, 2014 Author Share Posted September 24, 2014 Nice one, thank you. I'll be safe if I have 3L on hand then. Link to comment Share on other sites More sharing options...
trebor69 Posted September 24, 2014 Share Posted September 24, 2014 That should be plenty. Link to comment Share on other sites More sharing options...
Swampy442 Posted September 24, 2014 Share Posted September 24, 2014 And make sure the engine is running, its in P and on a flat surface Link to comment Share on other sites More sharing options...
trebor69 Posted September 24, 2014 Share Posted September 24, 2014 And make sure the engine is running, its in P and on a flat surface Link to comment Share on other sites More sharing options...
