r0cknr0lla Posted September 23, 2014 Share Posted September 23, 2014 (edited) Hi guys, I know this may not be an easy one to explain but can anyone help me with advice as to what holes I can close up for the engine bay wiretuck smooth over. Being a new supra owner and not having a motor in when car arrived does affect my knowledge regarding this and therefore only am aware of fuze box, battery and loom holes.. nothing else was available to check what goes where. Cheers. Edited September 23, 2014 by r0cknr0lla (see edit history) Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted September 25, 2014 Author Share Posted September 25, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
abtin90 Posted September 25, 2014 Share Posted September 25, 2014 Have a look at kaan W's build thread and Johns thread for the kraken there's plenty of pictures detailing it. Sorry I can't be of more help. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 25, 2014 Share Posted September 25, 2014 Well depends, are you deleting anything or relocating stuff out of site? Also depends what engine is going in and what stuff your has fitted. For instance if you relocate stuff like the battery, igniter packs, fuse box, and relays or if your deleting stuff like ABS, AC etc will make a big difference. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 25, 2014 Share Posted September 25, 2014 here a jist from memory to help. There hundreds, depends like I say on what is staying and spec etc Theres loads on the front too, like horn brackets, oem bonnet stay, battery clamp, couple of randoms. Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted September 25, 2014 Author Share Posted September 25, 2014 Thats great thanks guys, anything helps at the moment. Abs and ac being deleted yes. Going TT non vvti. Will be relocating the box and battery and binning the charcoal cannister. No stock airbox either. Regarding the relays and ignitors is it better to relocate them to inside the cabin? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 26, 2014 Share Posted September 26, 2014 In that case the vast majority in the top right hand side of the bay in the picture can be filled, as can most of the front right hand side. If your running an after market inlet the brackets on the left suspension side can go and allot of wholes filled, there is some holes in the top left that are cruise control related too. As for the relays and ignite, you could mover it down low in the bay onto the chasis rail or put it behind the wing, would probably be easier than moving it into the car IMO Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted September 26, 2014 Author Share Posted September 26, 2014 Cheers mate thanks for the help. Makes the world of difference. Had a look at hodges too so should be good to go now. Is there no concern of getting the electics wet fitting them under the wing? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 26, 2014 Share Posted September 26, 2014 If they are under the skin of the wing they shouldn't get wet as they will be completely incased. Would be a pita if they had a fault though. No different to having it under the bonnet I shouldn't have fault. Good luck mate, bit of an epic job. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 26, 2014 Share Posted September 26, 2014 Whatever you end up doing, I would recommend finding a local member with a TT, and have a good look around the engine bay of their car. Quote Link to comment Share on other sites More sharing options...
Steve Posted September 26, 2014 Share Posted September 26, 2014 I would not advise fitting the fuse box under the wing after seeing fuse boxes full of water and corroded when moved. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 27, 2014 Share Posted September 27, 2014 I would not advise fitting the fuse box under the wing after seeing fuse boxes full of water and corroded when moved. Definitely agree with this, the fuse box should be in the car as most locations will only allow you to mount it on its side or at an angle and the casing will just allow water straight in. Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted September 27, 2014 Author Share Posted September 27, 2014 Agreed, I wasnt planning on going there purely for that reason. Seems to be the headlight as an option too but the water issue is still a concern. In two minds about where to place it. If tucking the loom under the wings I suppose the most sensible is to place the relays etc along with it I suppose. I will pm hodge and see where he has placed his as a reference. Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted September 27, 2014 Author Share Posted September 27, 2014 Whatever you end up doing, I would recommend finding a local member with a TT, and have a good look around the engine bay of their car. Good idea, There is a thread with london members so may take advantage of that! Cheers Quote Link to comment Share on other sites More sharing options...
safcdixon Posted September 27, 2014 Share Posted September 27, 2014 I would not advise fitting the fuse box under the wing after seeing fuse boxes full of water and corroded when moved. This actually happened to me just a few weeks back, i moved my small relay box (trac,abs) under the headlight a couple of years back, it was full of grit and water, all three of my relays had corroded so badly that they were bridging and make my whole system stay live with the ignition off If you have the skills move it in the cabin or delete the abs and trac system altogether, if not leave where it is Quote Link to comment Share on other sites More sharing options...
r0cknr0lla Posted September 27, 2014 Author Share Posted September 27, 2014 Cheers for that.. think il just go the extra length and place them in the cabin. Solves a world of problems later. Quote Link to comment Share on other sites More sharing options...
