a98pmalcolm Posted September 23, 2014 Share Posted September 23, 2014 Can anyone advise what this issue may be? Sometimes its not there at all and then comes back with a little or alot. Most of the time it take a good warm up of the car to start. Going 30mph or above stops it. You can actually feel the creek through the steering wheel So it seems to be when there is pressure on the steering causes the issue.. Anyone else had this? Many thanks Paul https://www.youtube.com/watch?v=eAOOtuxiaQ4&feature=youtube_gdata Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 24, 2014 Author Share Posted September 24, 2014 Anyone know of the issue? Thanks Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 24, 2014 Share Posted September 24, 2014 Dry Universal Joint in the column? Dry Column Bearings? Loose Subframe? Sounds mechanical not hydraulic. Just go through the basics and you'll find it easy. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 24, 2014 Share Posted September 24, 2014 Sounds like dry rubber. As above, get the lube out. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 25, 2014 Author Share Posted September 25, 2014 Ok thanks fellas... Quote Link to comment Share on other sites More sharing options...
