Mikalor clamp size for stock inlet...
supra_ufo
how thick is the pipe bud? are you using stock black pipe or some sort of samco hose?
if you use a samco and its around 4mm thick(maybe thicker) then you are looking at the size 79mm-85mm
because you have the internal which is 74 + the extra 8mm thickness pipe = 82mm
it will compress down when clamped but if you were to get the 73-79mm clamp you would have a hard game getting it on and you wouldnt get the 68-73mm on at all bud
if your still using the stock pipe then you can just check the thickness and work it out bud or post back
i forgot the thickness of the stock pipe but i think it maybe close to 4mm,
