trebor69 Posted September 21, 2014 Share Posted September 21, 2014 (edited) Help please, Having issues with my engine missing and stuff, just decided to check the timing and need confirmation that I'm checking it correctly and that it IS two teeth out.... Lined up bottom pulley mark on "0" on bottom cover also have screwdriver in first cylinder to make sure its TDC cam gear marks should be at twelve 0 clock and not two teeth to the right (3 minutes past'ish) Is my timing set wrong? Thanks Edited September 21, 2014 by trebor69 (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 21, 2014 Share Posted September 21, 2014 Sounds like it to me. There are dots on the cam gears and arrows pressed into the plate behind the gears, they should line up. Pictures always help though. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 21, 2014 Share Posted September 21, 2014 Should show it in here http://www.mkivsupra.net/vbb/content.php?65-Engine-Mechanical-(2JZ-GE) Quote Link to comment Share on other sites More sharing options...
trebor69 Posted September 21, 2014 Author Share Posted September 21, 2014 Bottom one is defo on the "0" mark and the top ones are here Quote Link to comment Share on other sites More sharing options...
trebor69 Posted September 21, 2014 Author Share Posted September 21, 2014 Should show it in here http://www.mkivsupra.net/vbb/content.php?65-Engine-Mechanical-(2JZ-GE) Yes I've been through that and just want clarification before I slip the belt off and turn them back...... thanks mate Quote Link to comment Share on other sites More sharing options...
Ric Posted September 21, 2014 Share Posted September 21, 2014 There are 2 timing marks on the crank pulley.. Perhaps worth mentioning it isnt a 2jz in the picture, perhaps the timing method is different? Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted September 21, 2014 Share Posted September 21, 2014 Looks out to me, it should line up. Quote Link to comment Share on other sites More sharing options...
trebor69 Posted September 21, 2014 Author Share Posted September 21, 2014 It was the timing......all fixed now and very happy, thanks all Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted September 21, 2014 Share Posted September 21, 2014 Very lucky you didn't damage any valves That's one thing I love about the 2JZ-GTE non vvti that I have, non interference with the valves as long as you haven't changed the cams. Quote Link to comment Share on other sites More sharing options...
trebor69 Posted September 21, 2014 Author Share Posted September 21, 2014 I guess the 1jz I have is non interference too.... Thankfully :-) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 21, 2014 Share Posted September 21, 2014 All JZs are non interference Quote Link to comment Share on other sites More sharing options...
trebor69 Posted September 21, 2014 Author Share Posted September 21, 2014 Very good to know and fantastic engines, I believe they are made by Yamaha like the 3sge in the Celica..... Also non interference :-) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 22, 2014 Share Posted September 22, 2014 Yamaha have worked with Toyota since the 60s, had a hand in lots of engine, the latest being the LF-A V10 Quote Link to comment Share on other sites More sharing options...
