2JZ Guru, i need your help :) My engine do strange noise and vibrations
avernaz
Hi Mate,
I need some help.
My specs :
Supra TT 1994 Euro spec (same UK)
Engine stock with oem twin.
73'000 kms
After 2 years, with a little kms done, my engine do strange accceleration.
2013 : Past year, 2nd turbo have difficult to boost (engage and cut ???) but after warming and some kms done, my car reboost like a charme.
Some days later, test and same problem.
2014 : Take time to fix the problem, i have change some vaccum hose with no change :(
Today, i have put new coil pack and change the plastic connector, no change.
At low rpm, i have strange vibrations, my exhaust smell fuel !
Thanks in advance for your help and tips ... sorry for my bad english.
Regards,
Alex
Edited by avernaz (see edit history)
sounds like a knock, but when at back sounds like a plug/coil pack gone...
Coil pack and connector plug are new.. :think: , same sympthom with old or new. I need to try to remplace sparks plugs. They have 4000 kms, look normaly, but 4 years old.
What do you think "sounds like a knock" ? sensor defect ?
Thanks
