Bally Posted September 10, 2014 Share Posted September 10, 2014 Hi all when I turn on the lights in my 95 j spec the odo light goes off and there's no dash light anyone had similar issues ?? Link to comment Share on other sites More sharing options...
mellonman Posted September 11, 2014 Share Posted September 11, 2014 things like that are normally caused by a wire earthing out , do your lights actually come on when switched Link to comment Share on other sites More sharing options...
Ric Posted September 11, 2014 Share Posted September 11, 2014 The lights will dim when you turn on the lights. Then you can adjust the dimming by the circular nob on the right side of the dash, if it's turned all the way down it may look like they are off, try turning it up. Link to comment Share on other sites More sharing options...
mellonman Posted September 11, 2014 Share Posted September 11, 2014 The lights will dim when you turn on the lights. Then you can adjust the dimming by the circular nob on the right side of the dash, if it's turned all the way down it may look like they are off, try turning it up. haha yeah there is that , if they are dimming then its doing what its ment to do and there is no problem lol Link to comment Share on other sites More sharing options...
Bally Posted September 13, 2014 Author Share Posted September 13, 2014 Thanks for the replies it turned out to be the middle wire on back of dimmer that had come off sorted now Link to comment Share on other sites More sharing options...
