GSR2007 Posted September 10, 2014 Share Posted September 10, 2014 Hi folks I have a 95 tt w58,after a top speed run on the local runway,my engine check light came on but went off about 10 seconds after,and the car just doesn't seem to be running right since,I have my full power but the car sounds somewhat strange on idle,when I start the car is seems like it's starting quicker than normal also and sounds like there's a slight rattle coming from the exhaust I've also noticed it's a bit smokey when I rev it not a major excess of smoke but it is noticeable? Could my j-spec turbos be on there way out? What I've never noticed before is slight oil deposits on my air intake pipe coming from my ssqv? Can anyone shed me some light..my oil pressure and water temp is all perfect also Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted September 10, 2014 Share Posted September 10, 2014 First thing to do, would be check for error codes stored on the ecu - the paperclip method is the easiest, and will give you a head start Quote Link to comment Share on other sites More sharing options...
GSR2007 Posted September 11, 2014 Author Share Posted September 11, 2014 Done the paper clip method and got error code 42 speed sensor would this be triggered but my car exceeding the factory jdm restrictor? Also would it show symptoms in the original post? Quote Link to comment Share on other sites More sharing options...
