peter richards Posted September 5, 2014 Share Posted September 5, 2014 just cheched my oil all seems ok golden colour on the dip stick , but had a look into the neck and it looks pretty black and grimey. cleaned out as much as I could reach , but it looks black further down , any cause for worry or is it normal peter Link to comment Share on other sites More sharing options...
j_jza80 Posted September 5, 2014 Share Posted September 5, 2014 If the car hasn't been used a lot, or not been warmed up properly for a while, it is probably just condensation, which is normal. Link to comment Share on other sites More sharing options...
peter richards Posted September 5, 2014 Author Share Posted September 5, 2014 yes not used much , could do with an oil change although it looks golden , feels ok , probably been in there a few years Link to comment Share on other sites More sharing options...
Dnk Posted September 6, 2014 Share Posted September 6, 2014 Black and grimey means its been there for a while, where exactly are you cleaning ? i'd leave well alone unless you can take the part off and clean it properly. I'm guessing the cam cover, if so if you want to clean them remove them Link to comment Share on other sites More sharing options...
Ric Posted September 6, 2014 Share Posted September 6, 2014 Short journeys without proper warm up can create larger than normal carbon deposits and stuff which will be the black stuff you are seeing? If the oil it'self is golden it's probably just build up, as DNK says though, take the covers off to clean properly rather than dislodging something into the depths through the oil filler. Link to comment Share on other sites More sharing options...
Paul372 Posted September 6, 2014 Share Posted September 6, 2014 Sounds like it's had abit of pour maintenance over its time and its burnt oil due to not changing the oil regularly, I wouldn't try cleaning it unless you take it apart just incase you drop a lump of grim down there Link to comment Share on other sites More sharing options...
peter richards Posted September 6, 2014 Author Share Posted September 6, 2014 ok thanks its only recently not been serviced as I had other problems to resolve Link to comment Share on other sites More sharing options...
