TT Paul Posted September 3, 2014 Share Posted September 3, 2014 (edited) spec tt jspec full bpu 400lph pump 12v pump mod (for single) later in yr stage 1 hks cams boost controller afr gauge stock ecu, injectors fcd fault seems like a miss fire, holds back around 4000rpm and continues, been gradual over a few wks then got worse. alot worse in ttc. not really jerky but you can feel it and the kick with 2nd turbo is not as hard. boosting fine, afr on WOT sits around 12, new plugs just fitted ngk iridium, no fault codes, checked pipes no leaks i can find, manifold pressure valve i can blow into but won't let me suck air through, idle is fine no missfire so any help with DB coming up thanks. its bugging me as i can't fix it. Edited September 4, 2014 by TT Paul (see edit history) Link to comment Share on other sites More sharing options...
DodgyRog Posted September 3, 2014 Share Posted September 3, 2014 Sounds similar to mine Paul, it turned out to be a Coilpack starting to go, but was told it could just be a clip also Link to comment Share on other sites More sharing options...
TT Paul Posted September 3, 2014 Author Share Posted September 3, 2014 hmm i have got newish superspark coilpacks well about 7yrs old and coilpack clips done in feb.. coilpack next guess its one out one in see effects.. Link to comment Share on other sites More sharing options...
Nic Posted September 3, 2014 Share Posted September 3, 2014 Was it running okay before? What grade plugs have you fitted? Link to comment Share on other sites More sharing options...
TT Paul Posted September 3, 2014 Author Share Posted September 3, 2014 was doing it with other plugs just fitted BKR8EIX, went for drive after fitting new plugs, fault still there but not as much it's baffled me Link to comment Share on other sites More sharing options...
jcbt Posted September 3, 2014 Share Posted September 3, 2014 Paul mine was misfiring at 5k revs on Dragonball with 12 month old non oem coil packs. Changed them for proper Toyota ones and all was fine suggest try this as misfires are normally plugs coil packs or clips Link to comment Share on other sites More sharing options...
mellonman Posted September 3, 2014 Share Posted September 3, 2014 agreed super sparks are not no cop i had the same as above , had a miss with them went back to my old toyotas and sorted the misfire i would say 7 year old super sparks have seen there day Link to comment Share on other sites More sharing options...
TT Paul Posted September 3, 2014 Author Share Posted September 3, 2014 coilpacks then? next thanks will give that a try. Link to comment Share on other sites More sharing options...
Scooter Posted September 3, 2014 Share Posted September 3, 2014 Can't find it but I recall someone's actual loom in the plug area being worn through or having exposed wires...will keep searching. Link to comment Share on other sites More sharing options...
TT Paul Posted September 3, 2014 Author Share Posted September 3, 2014 Can't find it but I recall someone's actual loom in the plug area being worn through or having exposed wires...will keep searching. oh great it gets better!! i hope its not that bad. Link to comment Share on other sites More sharing options...
Scooter Posted September 3, 2014 Share Posted September 3, 2014 I don't think it was 'that' bad to fix just unexpected... Link to comment Share on other sites More sharing options...
TT Paul Posted September 3, 2014 Author Share Posted September 3, 2014 I don't think it was 'that' bad to fix just unexpected... see how it goes try coilpacks first easy to do with a meter on ohms. hot/cold temp readings Link to comment Share on other sites More sharing options...
Lee P Posted September 3, 2014 Share Posted September 3, 2014 Coil packs Fit new Toyota ones. I've had loads of issues with super spark I keep the Toyota ones in stock at a reduced price Link to comment Share on other sites More sharing options...
TT Paul Posted September 4, 2014 Author Share Posted September 4, 2014 well done a ohms test on the coilpack pins nothing showed. after some googling a few sites say that you won't really get a reading with a meter due to low resistance, and best to change them to find faulty unit so that will be next.. Link to comment Share on other sites More sharing options...
TT Paul Posted September 4, 2014 Author Share Posted September 4, 2014 well thanks for help it was the coils found out by swapping out and then driving all sorted Link to comment Share on other sites More sharing options...
DodgyRog Posted September 4, 2014 Share Posted September 4, 2014 What do I get as the first to diagnose and post Glad it's an easy one to sort for a change Link to comment Share on other sites More sharing options...
TT Paul Posted September 4, 2014 Author Share Posted September 4, 2014 well rog you win first place on the forum to post in my post Link to comment Share on other sites More sharing options...
