ShawnPreece Posted September 3, 2014 Share Posted September 3, 2014 I need to replace the powersteering pump on my supra as it makes a fair noise when the engine is cold before it gets up to temperature, I do have one off a mkiii turbo supra at home and im guessing they are different but just on the off chance it might be the same I thought id ask on here? and if not then how specific are they to tt or na engines as my engine is a vvt-i twin turbo but i have found one on ebay (link below) off a non turbo so just checking this would fit before I purchase it? assuming that my mkiii doesnt fit of corse. http://www.ebay.co.uk/itm/Toyota-Lexus-Power-Steering-Pump-2zj-ge-3-0-non-turbo-Supra-JZA80-GS300-LS300-/301272064069?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item462536e045 Link to comment Share on other sites More sharing options...
SupraP-Z Posted September 3, 2014 Share Posted September 3, 2014 Have you checked your fluid colour/levels? I had a really bad noise coming from mine, and it was driven for a long time with that as well. After a full flush, cleanout of the gauze filter at the bottom of the pump and new fluid in...its as sweet as a nut, no lightsabre noises for me! Link to comment Share on other sites More sharing options...
ShawnPreece Posted September 3, 2014 Author Share Posted September 3, 2014 Have you checked your fluid colour/levels? I had a really bad noise coming from mine, and it was driven for a long time with that as well. After a full flush, cleanout of the gauze filter at the bottom of the pump and new fluid in...its as sweet as a nut, no lightsabre noises for me! ahh right cheers might be worth a change of fluid 1st then and see if it makes a difference cheers Link to comment Share on other sites More sharing options...
Nic Posted September 3, 2014 Share Posted September 3, 2014 The part number for the PAS pump is the same on all TT Supras (all years and models). The NA and MKIII are different part numbers. Link to comment Share on other sites More sharing options...
ShawnPreece Posted September 3, 2014 Author Share Posted September 3, 2014 The part number for the PAS pump is the same on all TT Supras (all years and models). The NA and MKIII are different part numbers. ahh thats brilliant thankyou so the one I have at home off a mkiii turbo should be fine on my TT mkiv then cheers Link to comment Share on other sites More sharing options...
Nic Posted September 3, 2014 Share Posted September 3, 2014 ahh thats brilliant thankyou so the one I have at home off a mkiii turbo should be fine on my TT mkiv then cheers No that's not what I meant, all MKIV JZA80 TT Supra PAS pumps are the same. The MKIII Supra is a different part number. Link to comment Share on other sites More sharing options...
ShawnPreece Posted September 3, 2014 Author Share Posted September 3, 2014 No that's not what I meant, all MKIV JZA80 TT Supra PAS pumps are the same. The MKIII Supra is a different part number. ahh sorry misunderstood, ok tidy thankyou for your help Link to comment Share on other sites More sharing options...
