supra_24 Posted September 2, 2014 Share Posted September 2, 2014 Hey guys, just a quick one regarding some new alloys/tyres I purchased for my supra. Looking to find out what the recommended tyre psi would be for front and rear? Tyres are Falcon 245/35x18inch Front & 295/30x18inch Rear. Any advise would be appreciated. Regards Ash Link to comment Share on other sites More sharing options...
MattP Posted September 2, 2014 Share Posted September 2, 2014 30 all round and adjust based on tyre wear after 500-1000 miles. stock is a bit higher but with bigger tyres its trial and error I would think try the search box in the top right or google keywords for a more clear idea. Link to comment Share on other sites More sharing options...
supra_24 Posted September 2, 2014 Author Share Posted September 2, 2014 Cheers mate, appreciate that. 30psi or around that was what I had in mind as first thoughts. Link to comment Share on other sites More sharing options...
Supraleeturbo Posted September 2, 2014 Share Posted September 2, 2014 the correct psi is 34 front 32 rear Link to comment Share on other sites More sharing options...
MattP Posted September 2, 2014 Share Posted September 2, 2014 I have stock tyre pressures in my 17s with stock sized Tyres (F)235/45/17 ®255/40/17 In my 18s have 32psi (F) and 30psi ® on 18s with 235/40/18 and 255/35/18 - - - Updated - - - the correct psi is 34 front 32 rear In stock size tyres on 17s..... Link to comment Share on other sites More sharing options...
Nic Posted September 2, 2014 Share Posted September 2, 2014 I'd start with stock pressures, then spend some time driving the car in the dry and wet, then adjust by a couple of psi at a time to get to what suits you best. Ideal tyre pressures will vary also depending on the brand of tyre you are using eg. my Toyo T1R tyres have a softer side wall and perform better on the road with a couple of extra psi above stock. Link to comment Share on other sites More sharing options...
MattP Posted September 2, 2014 Share Posted September 2, 2014 I'd start with stock pressures, then spend some time driving the car in the dry and wet, then adjust by a couple of psi at a time to get to what suits you best. Ideal tyre pressures will vary also depending on the brand of tyre you are using eg. my Toyo T1R tyres have a softer side wall and perform better with a couple of extra psi above stock. Exactly... Link to comment Share on other sites More sharing options...
Dnk Posted September 2, 2014 Share Posted September 2, 2014 Hot or cold Uk cars on 17's were 34 front and rear when cold if i remember correctly Link to comment Share on other sites More sharing options...
Nic Posted September 2, 2014 Share Posted September 2, 2014 It usually says on a label on the inside of the door jam what the standard pressures should be. Link to comment Share on other sites More sharing options...
Jellybean Posted September 2, 2014 Share Posted September 2, 2014 OEM recommendation is 36 psi all round , if you car is running the OEM rolling radius , you should be running 36 psi I played around with ranges from 32-36, I found a happy medium with 33-34 psi with regards tyre wear and comfort , with 36 psi I just found too much tramplining I run 19 35 245 and 19 35 285 rears , from the stock rolling radius the fronts are out by 1.68 % , the rears are out by 6.03% , Ideally I should be running a 30 profile rear OEM Tyres - front 235/45ZR-17 OEM Tyres - rear 255/45ZR-17 http://www.carbibles.com/tyre_size_calculators.html Link to comment Share on other sites More sharing options...
Dnk Posted September 2, 2014 Share Posted September 2, 2014 The WSM says 33 front and rear Stock rear tyres are 255 40 17 Link to comment Share on other sites More sharing options...
MattP Posted September 2, 2014 Share Posted September 2, 2014 The WSM says 33 front and rear Stock rear tyres are 255 40 17 Thats what my 17s are^ as the front sits higher same concept on my 18s 40 on the front 35 on the back Link to comment Share on other sites More sharing options...
Jellybean Posted September 2, 2014 Share Posted September 2, 2014 The WSM says 33 front and rear Stock rear tyres are 255 40 17 My bad got it from here they are a 45 profile http://mkiv.supras.org.nz/specs.htm Link to comment Share on other sites More sharing options...
