SupraP-Z Posted September 2, 2014 Share Posted September 2, 2014 Ok so this problem started last week, bit of an odd one. Cold start, sometimes the car just doesn't fire, turn the key and click click...like the battery is dead (it isn't, ive been driving it everyday) then I leave it for a few seconds, turn the key - it starts to crank and then dies again. Then lock and unlock the car and sometimes it fires into life. At times its immediate, and others it takes quite a few goes. Takes a little while...bit frustrating and worrying especially when im late for work! Im thinking a bad ground connection somewhere on my alarm system, maybe cleanup the battery terminals with some emery paper and then re-tighten. Or maybe starter motor? Could the starter motor cause these symptoms? Any help is appreciated as always Quote Link to comment Share on other sites More sharing options...
Ric Posted September 2, 2014 Share Posted September 2, 2014 Battery dead with a bad alternator? not charging the battery. Or probably something related to the alarm immobilisation circuit as you say, that could be anything. Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted September 2, 2014 Author Share Posted September 2, 2014 Def not battery dude, as when it does crank properly, it sounds completely healthy and fires up with no problem. Its a weird one, I had a similar problem when I forgot to tighten the negative terminal on the battery. First point I will check will be that, but im sure the battery is fine otherwise it wouldn't crank at all Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 2, 2014 Share Posted September 2, 2014 Could be the solenoid contacts burnt away, or brushes / commutator worn. I have a starter here with new contacts and a full check over that I would sell on an exchange basis. Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 2, 2014 Share Posted September 2, 2014 Mine did this. I undone the main feed into the Starter and redone it up no problems since No idea what made it do it or how i fixed it Quote Link to comment Share on other sites More sharing options...
stevie_b Posted September 2, 2014 Share Posted September 2, 2014 My guess is starter motor contacts need replacing. I had starting problems once, where leaving it for a few seconds would mean it would fire up strongly. See here: http://www.mkivsupra.net/vbb/showthread.php?70712-Car-reluctant-to-start Quote Link to comment Share on other sites More sharing options...
quarryman Posted September 2, 2014 Share Posted September 2, 2014 Quote Link to comment Share on other sites More sharing options...
Abz Posted September 2, 2014 Share Posted September 2, 2014 My guess is starter motor contacts need replacing. I had starting problems once, where leaving it for a few seconds would mean it would fire up strongly. See here: http://www.mkivsupra.net/vbb/showthread.php?70712-Car-reluctant-to-start My guess would be this too though I'd double check the battery connections are all good and well. Did you say you have an engine immobiliser fitted too? Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted September 2, 2014 Author Share Posted September 2, 2014 (edited) Mine did this. I undone the main feed into the Starter and redone it up no problems since No idea what made it do it or how i fixed it I may try this to temporarily solve this issue, maybe clean up the contacts and see how it goes My guess is starter motor contacts need replacing. I had starting problems once, where leaving it for a few seconds would mean it would fire up strongly. See here: http://www.mkivsupra.net/vbb/showthread.php?70712-Car-reluctant-to-start These are the exact same symptoms that im having, a single click and everything dead, then at random times it decides to fire. I also thought it may be my immobiliser as i armed/dearmed it thinking it locked itself. After reading your thread, im pretty confident its got to be the starter motor, thanks for the link dude My guess would be this too though I'd double check the battery connections are all good and well. Did you say you have an engine immobiliser fitted too? Yeah dude, bloody toad alarm lol. My symptoms are exactly the same as stevie b's, so im quite sure its what it is. Could be the solenoid contacts burnt away, or brushes / commutator worn. I have a starter here with new contacts and a full check over that I would sell on an exchange basis. Spot on as usual Mr Wilson I would definately be interested in this, im afraid that one day the car just wont start. I remember there being a thread on here about refurbing them? Rather have a nice new one, or mine refurbed atleast. How much would i be looking for, for the exchange? Thanks all for the replies and suggestions Edited September 2, 2014 by SupraP-Z (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 2, 2014 Share Posted September 2, 2014 To be sure it's solenoid contacts or brushes, when the starter *WON'T* turn, take a bar and strike it fairly hard on the body, you can just get at it with a long bar from above. if it then miraculously starts working, you know it needs a re-con. Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 3, 2014 Share Posted September 3, 2014 I should also add i beat it, and earthed onto the bodyto check what it was. Mine point blank refused to start at no point prior to removal of said wire was it going to start. Quote Link to comment Share on other sites More sharing options...
