jsnlvxr Posted September 1, 2014 Share Posted September 1, 2014 I guys I currently have a na auto pre facelift which im going to be getting a tt engine fitted. its currently running standard set up so I assume no rear lsd. what diff would be best to fit? could I fit a standard diff from a tt model.if so what are they called as ive heard of a few types I beleive? big case etc thanks Quote Link to comment Share on other sites More sharing options...
Nic Posted September 1, 2014 Share Posted September 1, 2014 A factory fitted LSD was optional on most models, the axle code on the VIN plate will tell you if has an LSD or not. If the code ends with an A it is an open diff, if it ends with B it has an LSD. Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted September 1, 2014 Author Share Posted September 1, 2014 ah ok brilliant thanks.I will take a look when I get home. im guessing it hasnt though. Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted September 1, 2014 Author Share Posted September 1, 2014 (edited) hasnt got a lsd Edited September 1, 2014 by jsnlvxr removing pic (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 1, 2014 Share Posted September 1, 2014 I would remove that picture sharpish mate, you wouldn't want a clone made up Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 1, 2014 Share Posted September 1, 2014 You clearly have a diff, just not the one you want Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted September 2, 2014 Author Share Posted September 2, 2014 any advice on which lsd to use guys? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 2, 2014 Share Posted September 2, 2014 41301-JS402 TRD LSD http://trdparts.jp/english/parts_lsd_mechanical.html Quote Link to comment Share on other sites More sharing options...
