mac79 Posted August 31, 2014 Share Posted August 31, 2014 I was coming down the motorway this afternoon and the car started coughing and spluttering and died. I manged to get it restarted and drove fine. I came to use it again and started running rough and cutting out then will run and then the revs are up and down and it feels like its not getting enough fuel. Managed to get it to tick over with it missing quite a bit, if you rev it a bit of black smoke come out but not constantly and its smells really rich. Boost gauge is reading ok and it had a new fuel pump fitted 2 weeks ago. Has anybody got any ideas. Link to comment Share on other sites More sharing options...
absz Posted August 31, 2014 Share Posted August 31, 2014 As a guess faulty crank sensor if its back-firing aswell, or possible wrong fuel? Link to comment Share on other sites More sharing options...
mac79 Posted August 31, 2014 Author Share Posted August 31, 2014 (edited) I always used v power. I had just come back from derby on the same fuel with no bother. I have just tried it again and i can only just use a bit of throttle and gently it keeps running but get on it quick it hesitates when I drove it round the blocķ. Just heard a bit of a "knocking" and the turbo seems louder And the idle is reading on the boost gauge higher than normal and it up and down by 200rpm ish. Edited August 31, 2014 by mac79 (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 31, 2014 Share Posted August 31, 2014 if it's a twin turbo and has an FCD try bypassing it. Link to comment Share on other sites More sharing options...
gdog1989 Posted August 31, 2014 Share Posted August 31, 2014 I had a issue with the sender unit on my fuel pump after I changed it, mine cut out due to no fuel but was reading half full, when we took it back out it was floating in the tank swapped sender unit over all good, hope you solve your issue. Link to comment Share on other sites More sharing options...
mac79 Posted August 31, 2014 Author Share Posted August 31, 2014 if it's a twin turbo and has an FCD try bypassing it. It is a twin. Its a hks fcd I will have look at that. Link to comment Share on other sites More sharing options...
mac79 Posted August 31, 2014 Author Share Posted August 31, 2014 I had a issue with the sender unit on my fuel pump after I changed it, mine cut out due to no fuel but was reading half full, when we took it back out it was floating in the tank swapped sender unit over all good, hope you solve your issue. I am going to the guy who fitted it to have a look at that as well. Link to comment Share on other sites More sharing options...
mac79 Posted September 1, 2014 Author Share Posted September 1, 2014 It was the fcd as chris wilson said. I need to buy a new one. I am going to get a hks but I remember something about when used with an auto it needs to be a particular one or something needs to be done when wired in. Anybody know anything about this? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 1, 2014 Share Posted September 1, 2014 I know some people say the clamping method used by HKS is not ideal, and I agree, but there seems a gap in the marketplace for a reasonably priced alternative, since Thor and Greddy stopped making them. Assuming the damned thing works at all i have had no issues with HKS ones on manual and auto Supra TT's of all ages. Link to comment Share on other sites More sharing options...
mac79 Posted September 1, 2014 Author Share Posted September 1, 2014 (edited) I know some people say the clamping method used by HKS is not ideal, and I agree, but there seems a gap in the marketplace for a reasonably priced alternative, since Thor and Greddy stopped making them. Assuming the damned thing works at all i have had no issues with HKS ones on manual and auto Supra TT's of all ages. Cheers Chris I will order one later. Try and get it sorted for jae. Where is best to order one from? Edited September 2, 2014 by mac79 (see edit history) Link to comment Share on other sites More sharing options...
