np89 Posted August 30, 2014 Share Posted August 30, 2014 Hey guys, Having recently discovered my turbine housing is actually T3, I was wondering is it possible to change the housing to T4 to allow greater flow? Thanks Niall Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 30, 2014 Share Posted August 30, 2014 Of course, depending on who makes the turbo, garrett for example, you should be able to buy a housing from them. Or a T3 to T4 adaptor. Quote Link to comment Share on other sites More sharing options...
Nic Posted August 30, 2014 Share Posted August 30, 2014 http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-046&Category_Code=GTH Quote Link to comment Share on other sites More sharing options...
np89 Posted August 30, 2014 Author Share Posted August 30, 2014 A local turbo "specialist" insisted that they are completely different and thw blades etx are different and its not just a matter of swapping them. Am I to assume there is zero truth in this? Quote Link to comment Share on other sites More sharing options...
Nic Posted August 31, 2014 Share Posted August 31, 2014 (edited) A local turbo "specialist" insisted that they are completely different and thw blades etx are different and its not just a matter of swapping them. Am I to assume there is zero truth in this? He's wrong, if you look here you'll see all the different exhaust housings that are compatible with the GT35R http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=GRT-TBO-006&Category_Code=GRT Edited August 31, 2014 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
