blitz boost gauge fitted in heater vent and Controller fitted in DIN cubby with pics.
rossky
Hi All,
With alot of searching on here and beyond I have completed fitting the above, So a quick thread as there are already some nice article on fitting guides I thought I would just show how the work went for all to see.
So Firstly i cannot recommend highly enough how the 52mm blitz sd boost gauge fits into the heater vent, real snug fit, looks like it was made for it! just took out the 3 proged turbine and it all clipped together nicely, the gauge actually still moves similar to the vent did.
Second round of pics was where I decides to fit my Boost controller, basically cut the back off the top of the din cubby and use tie wraps to hold in place.
The last few pics were just to highlight a nice spot to run cables from the cabin to the engine bay, basically its a spare yellow unused rubber grommet located on the passenger side which runs from just above the lhs of the ecu to behind the charcoal cannister.
Pics were the in process work will get fitted dash pics up 2m.
Ross
