Guest Nicholas Posted August 29, 2014 Share Posted August 29, 2014 The gearing calculator seems to agree with me http://www.mkivsupra.net/vbb/showthread.php?225050-Supra-specific-gear-diff-ratio-and-tyre-size-calculator lol I guess the forum has conflicting info, I honestly thought the V161 had closer ratio's. Anyone got any Toyota tech info? it would be good to know for sure. Link to comment Share on other sites More sharing options...
JamieP Posted August 29, 2014 Share Posted August 29, 2014 (edited) V161 feels closer ratio, for me the gears are perfect, with a V160 I prefer using a UK auto diff as gears are to long I think. Edited August 29, 2014 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
Abz Posted August 29, 2014 Share Posted August 29, 2014 Seemed pretty even when we did a rolling start on Dragonball. I started a bit low on the power band on that race, though we were pretty evenly matched! The auto's are certainly quicker than the manual's - Each time I shifted I dropped and then was playing catching up. Link to comment Share on other sites More sharing options...
garethr Posted August 29, 2014 Share Posted August 29, 2014 (edited) I thought the gear ratios on the v161 were taller except for 6th? Comparison is here: - http://www.mkivsupra.net/vbb/showthread.php?35923-Manual-gearbox-ratios Edit: - Ratios here show the V161 is shorter. 6 Speed (V160) / (V161) 3.827 / 3.724 2.360 / 2.246 1.685 / 1.541 1.312 / 1.205 1.000 / 1.000 0.793 / 0.818 3.280 / 3.192 3.266(all TT) / 3.769(NA) Lower number:1 = higher (longer/taller) gearing -- fewer revs at a given road speed. Higher number:1 = lower (shorter) gearing -- more revs at a given road speed. No code has to be inserted here. Based on those numbers: 1-5 on the V161 are higher than the V160. 6 on the V161 is lower than the V160. Close ratio / wide ratio refers to the "gap" between the gears. No code has to be inserted here. Edited August 29, 2014 by garethr (see edit history) Link to comment Share on other sites More sharing options...
