brom86 Posted August 28, 2014 Share Posted August 28, 2014 (edited) Am i right in saying that the letters on the right side of the shifter should light up when headlights are on or all the time? Mine are off all the time apart from the manual button light which is working? If i have an issue can a change them to red led when fixed? Edited August 28, 2014 by brom86 (see edit history) Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted August 28, 2014 Share Posted August 28, 2014 There is a T10 bulb that lights up the lettering on the auto Replaced mine recently with a green SMD led Quote Link to comment Share on other sites More sharing options...
brom86 Posted August 28, 2014 Author Share Posted August 28, 2014 Is it easy to swap over and how many do I need? Thanks for the info dude, wanting to change all mine to red like this pic a found Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted August 28, 2014 Share Posted August 28, 2014 It's just the one bulb, I used one of these It's easy enough to do, just a matter of removing the shifter trim Quote Link to comment Share on other sites More sharing options...
mattdavies Posted August 28, 2014 Share Posted August 28, 2014 You can do it by removing the dash trim and sticking your hand underneath and feel for it Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 28, 2014 Share Posted August 28, 2014 There is a T10 bulb that lights up the lettering on the auto http://img.tapatalk.com/d/14/08/28/a2e4e5az.jpg Replaced mine recently with a green SMD led Have all your dash bulbs been replaced with LEDs? Looks really smart that. Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted August 28, 2014 Share Posted August 28, 2014 Used the same LEDs in the dash and did the heater controls too Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 28, 2014 Share Posted August 28, 2014 So they're all T10? Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted August 28, 2014 Share Posted August 28, 2014 The main dash uses 3xT10 & 1xT5 Ignition ring is T5 Heater is a mix of 3mm & 5mm LEDs and resistors Used this as a guide http://www.internetwork.org.uk/supra.htm Quote Link to comment Share on other sites More sharing options...
Kaan W Posted August 28, 2014 Share Posted August 28, 2014 I replaced all my heater controls with blue LEDs, not a job I would want to do again tbh but it looks good. Just wish I had gone for white instead. Quote Link to comment Share on other sites More sharing options...
