sCaz Posted August 27, 2014 Share Posted August 27, 2014 Hi, I am using 3G slit/drilled 323mm rotors with Porterfield fast road pads. Was on the track today and made my rotors really shine. I think i cooked my castrol srf react because brakes are really swampy now. Claim 1 (True or False it please): I guess the excess heat is mostly me being unused to track driving and doing the braking too early over a longer time and not doing it firmer and closer to the corner? Claim 2 (True or False it please): I am running too many laps without a pure cooling lap (3-5 full-on). I think they shouldn't heat up in excess if I brake later but harder but I would also like some input to other things I could do with my car. Can someone recommend a pad that works great on track for the supra UK/EU spec brakes? Is it a good idea to tunnel in some more air directly in front of the brakerotor with a 2.5" flex channel (http://badassparts.se/luftslang-2-5-silikon-300-c.html) Thanks in advance //Peter Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 27, 2014 Share Posted August 27, 2014 The carbon/ceramic Endless ones worked well on my car on track. Decent quality fluid, discs and pads make a huge difference. It won't be your driving on track though. Harder braking creates worse conditions than slower, softer braking. And if you're doing it right, you should be trying to set them on fire, anyway Link to comment Share on other sites More sharing options...
sCaz Posted August 28, 2014 Author Share Posted August 28, 2014 (edited) Should their be fireworks shooting passed your sidewindow entering a hairpin? ;-D I got the big brake (US/UK) and Porterfield Fast Road Pads + Castrol SRF React (new). What to change and in which order; Driving style, rotors, pads? Need to bleed the brakes cause they are really swampy now and I can hear the slits in the rotor so I guess the pads are looking like a smudged muffin by now... But it was fun! And again; any tips for good track pads? :-) Edited August 28, 2014 by sCaz (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 28, 2014 Share Posted August 28, 2014 If you boil brake fluid the pedal just goes straight to the floor. Boiling SRF takes some doing.... I prefer stock discs to fancy drilled or slotted stuff, usually done on cheap Taiwanese castings. You probably need a race pad, Porterfield do an R4 compouind, but it contains a lot of sintered iron, so expect rusty dots on the paintwork where irridescent particles fuse to it, and wheels that will look like they are rusty. Very noisy and dirty, but reasonably effective. Work adequately from cold. If you can duct air to the eye of the front discs it will make a huge difference to temperatures, but it takes some fabricating to make a duct to accept a cooling hose. Link to comment Share on other sites More sharing options...
SteveR Posted August 28, 2014 Share Posted August 28, 2014 If you can duct air to the eye of the front discs it will make a huge difference to temperatures, but it takes some fabricating to make a duct to accept a cooling hose. Bignum uses/used fabric conditioner bottles with the bottom haves chopped off and discarded. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 28, 2014 Share Posted August 28, 2014 When he gets the hang of things and starts going fairly quickly he'll find they melt Link to comment Share on other sites More sharing options...
bignum Posted August 28, 2014 Share Posted August 28, 2014 Lol, i don`t think chris has seen my latest vids:d Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 28, 2014 Share Posted August 28, 2014 You know I am just kidding, it's great to see people wring a car's neck on track, rather than stand looking at it in a field, with the tops of their underpants showing, and a tattooed wench akimbo on the bonnet Link to comment Share on other sites More sharing options...
bignum Posted August 29, 2014 Share Posted August 29, 2014 I know your sense of humour by now chris:), actually i ripped 1 of my softener bottles off at the mot station yesterday so need to make another before my next ring trip next month. Link to comment Share on other sites More sharing options...
Jellybean Posted August 29, 2014 Share Posted August 29, 2014 Carbone Lorraine pads are a good call too Link to comment Share on other sites More sharing options...
SteveR Posted August 29, 2014 Share Posted August 29, 2014 I know your sense of humour by now chris:), actually i ripped 1 of my softener bottles off at the mot station yesterday so need to make another before my next ring trip next month. Upgrade to TRD softener bottles his time Link to comment Share on other sites More sharing options...
sCaz Posted August 31, 2014 Author Share Posted August 31, 2014 Endless brakes was too expensive for my budget (£650+ for front pads?), waiting for an offer on a set of Carbotech XP10 which a friends who runs them cold (but in a much lighter car) recommended. What are your thoughts? If bleeding the fronts and this weeks normal braking makes the rotors and pads seem somewhat like they where before last wednesday, I'll have another trackday on saturday and then thats it for this summer. Definetly putting in 2.5" ducts, how should I spread/point the cold air.. just straight onto the shortside/ventilation of the discs? Lesson learned, quote created; "Big brakes aren't always good brakes. Good brakes are an expensive material sport that is aided by good braking techniques." Link to comment Share on other sites More sharing options...
