coza Posted August 27, 2014 Share Posted August 27, 2014 Hi not really sure how much these items are worth could sombody give me a rough guide From j spec supra - roughly around 70k miles W58 - flywheel W58 - bell housing W58 - prop N/A differential N/A diff drive shafts Cheers Quote Link to comment Share on other sites More sharing options...
listy Posted August 27, 2014 Share Posted August 27, 2014 Which diff is it? Quote Link to comment Share on other sites More sharing options...
coza Posted August 27, 2014 Author Share Posted August 27, 2014 Standard I think Quote Link to comment Share on other sites More sharing options...
SPG Posted August 27, 2014 Share Posted August 27, 2014 Standard I think Is this being removed from your own Supra? If so then you can lift the hood and check the tras/axel code, this will give you the differential code. The diff code should be: A0?A if it is the open differential, and A0?B if it is the LSD. Hope this helps Quote Link to comment Share on other sites More sharing options...
coza Posted August 27, 2014 Author Share Posted August 27, 2014 Diff is out the car :/ ,, But as for prices anybody got any rough ideas ?? Quote Link to comment Share on other sites More sharing options...
abtin90 Posted August 27, 2014 Share Posted August 27, 2014 The price on the diff would depend on which one it is so you'll need to look up the trans/axel code. As for the other parts I'm not too sure, my guess would be around £30-40 for the flywheel, and maybe £50 for the bellhousing. Not sure on the others. Quote Link to comment Share on other sites More sharing options...
